Hardware First Look: Gigabyte GA-P55-UD5 motherboard
Discussion in 'Article Discussion' started by Sifter3000, 14 Jul 2009.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. p3n
    p3n What's a Dremel?
    31 Jan 2002
    "that Gigabyte unhelpfully labels SATA3" .. only confusing if your a dyslexic clown?
  3. Paradigm Shifter
    10 May 2006
    They'll do whatever was set out in the NDA agreement in the event that you break it. Which would probably be two things; sue the crap out of you and make sure you never get another bit of Intel related kit early ever again. ;)
    I like the layout of that Gigabyte board a lot more than I liked the Asus one, with one exception; the location of the PATA connector.
  4. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Or if you're trying to do what the specifications demand:
    [quote='SATA 6Gbs specs (not exactly like that of course)]
    DON'T call it SATA3.0 or SATA3 or SATAIII!!![/quote]
    Nice board layout but then again they all seem to learn how to do it properly... sloooowly.
  5. Guest-16
    Guest-16 Guest
    This is why, in a nut shell. It should be called SATA 6Gbps. "SATA3" is too confusing with SATA 3Gbps.
  6. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    I must say i find this board a lot more desireable then the Asus one so far. Except for the orange PCIe slots that is, they are fugly.
    And the PATA connector... there's a lot more connectors on my motherboard that i'm ignoring, so i can easily add one more :)
  7. wyx087
    wyx087 Multimodder
    15 Aug 2007
    isn't it confusing to put 2 orange PCIe slots where 1 is connected to the CPU and the other is to the southbridge and cannot do crossfire?
    otherwise i really like this board. looks very promissing and may even be my next upgrade, if Bit-tech launch review says yay
    is the Intel's NAND chip going to be useful for, say 16GB RAM system?
    also, for the powered ESATA, what do i need, new cable that split into two on the other end?
  8. adidan
    25 Mar 2009
    This may be a daft question, please point it out if it is, but why does the CPC mounting socket on a Gigabyte board have itself plastered with Foxconn?
  9. adidan
    25 Mar 2009
    For CPC please read CPU.
    * facepalm *
  10. shadow
    shadow honky ponky
    7 Oct 2008
  11. Guest-16
    Guest-16 Guest
    Because Foxconn make a lot of the parts used in motherboard manufacture - it's a MASSIVE company. They are either the only company, or one of two companies that makes the LGA1156 socket.
    And charges a pretty penny for it too ("tens of dollars") - making P55 boards expensive at launch.
  12. Er-El
    Er-El Minimodder
    31 May 2008
    Disappointing really. No Sata 6gbps or USB 3.0 ports... STILL! And those standards have been published for a while now.
  13. Guest-16
    Guest-16 Guest
    There IS SATA 6Gbps!! Four ports!
    The only USB 3 controller available (NEC) is currently too expensive for P55.
  14. perplekks45
    9 May 2004
    Eeeehhh.... did you read the article? There are SATA 6Gbps ports.
    Damnit Bindi! You ninja'd me! :grr:
  15. adidan
    25 Mar 2009
    That, I did not know.
    Cheers.
  16. MgM*
    MgM* What's a Dremel?
    12 Aug 2008
    I have to say I like the duality of the e-sata and USB connections, i think thats pretty cool. with minimal real-estate at the rear it really makes sense to me.
    But 4 ram slots? does that mean we will start seeing i don't know 3gig dimms in the market for the new familly of CPU's?
  17. Guest-16
    Guest-16 Guest
    No, you'll simply see 4GB and 8GB kits, not 6GB and 12GB like with current LGA1366.
  18. Er-El
    Er-El Minimodder
    31 May 2008
    Oops I missed that part. Still, I'll skip this as it has SATA 6gigabit support on the motherboard itself when Intel already propose to integrate the southbridge on the upcoming Intel Core CPUs, and would also prefer a purely SATA 6gigabit design, as opposed to a mixture with SATA 3gbps ports.
    Oh and PS/2 ports...? Really? WHY!?
  19. Ross1
    Ross1 What's a Dremel?
    15 Feb 2009
    mmmm, 12 sata ports in total. sexy. Hopefully the gigabyte sata3 ports work better in the BIOS than the ones on the AM3 ud5 board that i have, it like to pair the ports together and made it difficult to get hard drives on the same 'pair' to work independently....
  20. Paradigm Shifter
    10 May 2006
    Because when a BIOS absolutely refuses to work with a USB keyboard... PS/2 is the only way. :)
Tags: Add Tags
