Hardware First Look: Kingston 128GB V+ SSDNow
Discussion in 'Article Discussion' started by Guest-16, 30 Jan 2010.
  1. Guest-16
    Guest-16 Guest
  2. samkiller42
    25 Apr 2006
  3. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    lol!
  4. Faulk_Wulf
    Faulk_Wulf Internet Addict
    28 Mar 2006
    Wait... Windows 7 hasn't been out that long. I know that performance and stress tests simulate an exponentially longer period of time then a real-life user can typically perform, but still... I thought plate drives lasted -years- in stress tests. If SSD's are failing just after 3 - 6 months of stress tests, that seems like a really short life expectancy. Something around maybe 5 years in real life? Maybe that's not much to many people on here, but two of my computers are that old, and my laptop is getting there.
    Of course without knowing the exact tests its hard to say, but if I'm shelling out $325 for a 128gb hard-drive it better be better then a plate-drive in --every-- way.
  5. Baz
    Baz I work for Corsair
    13 Jan 2005
    Rich is just joking - not broken any...yet!
  6. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    at least Toshiba is not using re-branded JMicron any more, i think he is more talking about the TRIM command making sure that it works i guess
  7. Guest-16
    Guest-16 Guest
    What happened to the Intel SSD after you thrashed it again? :D:D Oh the readers will have to wait to see that now :D
  8. Landy_Ed
    Landy_Ed Combat Novice
    6 May 2009
    What about the cheaper V range? any plans to perhaps do some side-by-side comparison to get some idea of relative value between the two?
  9. Guest-16
    Guest-16 Guest
    You mean the 40GB Intel drive? We haven't got the 30GB one from Kingston, but, tbh, 30GB is just too small.
    The older Toshiba JMicron one is pretty pants though and we wouldn't recommend it.
    We'll see if we have time about the 40GB X25-X
  10. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    I hope this is good - I need a decent but not too expensive SSD before my Window 7 RC expires :D
  11. Landy_Ed
    6 May 2009
    No, I actually mean the range below the one you've covered here.
    You've covered the V+ SSDNow, but there's also a more budget friendly range - http://www.kingston.com/ukroot/ssd/v_Series.asp
  12. leexgx
    28 Jun 2006
    Quite sure the V ones are the Toshiba/JMicron drives should avoid them like the plague
Tags: Add Tags
