Hardware First Look: Silverstone Raven RV02-E PC Case
Discussion in 'Article Discussion' started by Sifter3000, 4 May 2010.
  1. murtoz
    murtoz Busy procrastinating
    9 Apr 2008
    Me too!!
    Are you sure!?! Even 13 inch deep motherboards (SSI EEB form factor)? I believe I checked at the time and it wasn't quite roomy enough to take this...
  2. salesman
    salesman Minimodder
    29 Apr 2007
    As FelixTech said check the last picture it clearly shows 3 dust filters being pulled out at the bottom fans.
  3. Guest-16
    Guest-16 Guest
    TJ11 lovers - Computex in June 1 month away is the earliest I've heard we can see it. It won't be ready until "Q3" though so that could mean July-Aug-Sept.
  4. Krayzie_B.o.n.e.
    Krayzie_B.o.n.e. What's a Dremel?
    2 Aug 2009
    Mediocre cooling at best and not very pretty, I'll keep buying Raidmax Smilodon cases until they stop making them as having the motherboard door open is very conveinant plus they have fans that blow directly on your heatsink and GPU's.
    You want dust covers, go get some dryer sheets from your laundry room. Works better than any $5 dust cover I ever bought plus their cheaper and they make your room smell good.
  5. shaffaaf27
    shaffaaf27 The budget builder
    3 Jun 2008
    are these in shops yet? and if so, for cooling, these or the FT02 (With air penetrators?)
Tags: Add Tags
