Bits First Look: Windows 7 Beta Performance
Discussion in 'Article Discussion' started by Tim S, 16 Jan 2009.
  1. wyx087
    wyx087 Multimodder
    15 Aug 2007
    what i really don't understand is that why are XP users so looking forward to 7 whereas it's basically Vista, just look at version: Vista: 6000, 7: 6001.
    sure Vista got bad publicity, but since launch, it has been mostly problem free for me all the time. only problem i had was nVidia and ATI driver crashing, which WILL also happen in 7 seeing it's based on the same driver model.
    for 64bit, sure it can be an issue for "if it aint broken, don't fix it" people, but look at the number of developers who are unwilling to simply recompile their code into 64bit. the only way forward is to ditch the 32bit and go for the new one.
    for Win7 though, 32bit is necessary as it is also marketed towards the portable market, where 32bit is all it can run.
    all im saying is that Microsoft should simply do 3 version of Win7: Windows 7 Portable, Windows 7 Basic and Windows 7 Ultimate. where to simplify matters, the Ultimate is 64bit ONLY.
  2. GoodBytes
    20 Jan 2007
    Bauul... when we say ditch the 32-bit version, it means: "if you have a 64-bit processor, take the advantage of not using the 32-bit version, especially when you have no reason to not do so."
    Now if you have an old printer without 64-bit drivers (let's say), where your are in tight budget and don't have the funds to change it, but absolutely must switch Windows 7, then yes again, go with 32-bit.
    The problem is some people that do have the computer power, do have a 64-bit processor, have 2-3-4GB of RAM, and decide to have the 32-bit because they think it's better (because they think like with XP where the XP 64-bit is crap, or doesn't know in the field, or are misinformed, or didn't have the choice (ie: purchased a pre-assembled computer and no option to select the 64-bit version), or other reasons.
  3. GoodBytes
    20 Jan 2007
  4. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    The title sounds like cheap geek porn. Inside Windows 7: Going deep. :eyebrow:
    Will watch it once I'm at my girlfriend's house and have 'real' internet access (read: broadband).
    I will definitely go 64bit with Windows 7 but I downloaded the 32bit Beta because it's 1 GB smaller. Though I'm still pretty sure we all will have to go back to Vista/XP for quite some time before 7 hits the shelves. Beta ends June/August and retail is to be expected when? H209? Q409? 2010? I really hope it'll be released before the Beta expires and it looks pretty good if you ask me but it's still an OS and those always take their time.
  5. rembo666
    rembo666 What's a Dremel?
    6 May 2005
    I've been playing with Windows 7 for a few hours now and I absolutely love it. Even though I have a pretty descent machine ( Q6600 + 4G RAM + 8800 GT) it does seem to run noticeably faster than Vista, even though I'm running Windows 7 off of an old 120Gb IDE hard drive. Of course, Vista is not exactly slow on my machine, but I haven't seen OMFG slowdown moments that Vista likes to have every once in a while.
    The most "performance" gain I get is from the cleaned up user interface. I like the new unified task bar idea, but I'd like to see some kind of drawer system and I'd like an option for active applications to jump to the right of inactive shortcuts. One small feature that I LOVE is the ability to VPN into my office by clicking on the Networking tab. It's been greatly streamlined and is much more intuitive to use. I also like the new Snipping Tool and the new Paint. I'm a desktop graphics software developer and I tend to use Paint quite a bit, plus documenting stuff with screenshots just got a lot better.
    Another great feature is the fact that ALL Vista drivers work, even the ones that don't. Let me explain: some driver installation utilities won't start on an OS they don't know about. What an annoying "Feature" :wallbash:!!! Thankfully, all you have to do is right-click on the setup executable's icon and select "Troubleshoot compatibility"--problem solved! Microsoft also needs this feature for uninstallation though. I've encountered a problem removing one of the programs that I installed, because uninstaller kept telling me that "This installer only supports Win2k/XP/Vista". I've already installed the program, STUPID!!!
    I actually like Vista, but it does feel unpolished at times. It feels like you're having to pay for this new eye candy with performance. In Win7 it's a lot more seamless and natural, save for some weird window drag stuttering--supposed to be an NVIDIA driver problem. I think a lot of flamery about programs crashing in Vista should not be directed at Microsoft. They finally decided to put in controls that broke programs that SHOULD NOT HAVE BEEN RUNNING IN THE FIRST PLACE. It's sloppy coding that causes those crashes, not the OS!
    In conclusion. I like Windows 7. It's been completely stable for me so far, and it's just Beta 1. I'm getting me a copy as soon as this thing comes out. Meanwhile, I'm running all the betas and RC's until the release date.
    P.S.
    Does anybody know how to sign up for bug reporting? I got my copy off of MSDN and it will not let me "Send Feedback".
  6. rembo666
    6 May 2005
    I'm sure they'll have more betas and RCs before it comes out. Final Betas/RCs usually time out a couple of months after the software is released. I'm sure that's the case with MSDN version(s). I can't speak for public Beta, but I hope they have enough sense to do the same.
  7. GoodBytes
    20 Jan 2007
    Yea, you need to be a Microsoft partner. It's a 2500$US per month bases. yea.... it must be a checked with my name and send to me...
    Seriously, where you downloaded Windows 7, on the page (or e-mail) you should have Windows 7 product key. You need it to get out of the 30-day trial, and be able to send feedback to Microsoft.
  8. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    True, if only Intel had gone 64bit at the same time as the a64 the number of 32bit chips would be vastly reduced. My mums athlon xp is still doing the business but i'm not sure there are many boxes of that era still around and in daily use.
  9. UncertainGod
    UncertainGod Minimodder
    18 Oct 2007
    RC is due for April followed by release to manfacturers by August so expect it to be shipping on machines by November and Jan on the shelves in it's own box.
  10. kenco_uk
    28 Nov 2003
    Last I saw, most Pentium 4's have EM64T?
  11. cebla
    cebla What's a Dremel?
    6 Sep 2004
    Am I the only one who can't figure out why everyone thinks it’s a new feature to be able to put sidebar gadgets anywhere on the desktop? You can already do that in Vista.
  12. bubsterboo
    bubsterboo What's a Dremel?
    24 Jan 2006
    What about Windows 7's OpenGL performance? Windows Vista has considerably worse OpenGL performance vs XP. Atleast ive noticed a huge difference with OpenGL apps, like Maya and others.
    Wondering if it's as good as XP was.
    Could someone With a dual Boot of Windows 7 and Windows Vista run the OpenGL test on Cinebench? And compare the results.
  13. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    not this one...
  14. Kúsař
    Kúsař regular bit-tech reader
    23 Apr 2008
    Because if #7 is optimized Vista, why not just skip Vista :) .
    As a skilled XP user there are few things I don't like about Vista. Under XP I got used to finding 75% of all settings in control panel(clasical view - legacy of Win98 user interface!) and rest after right-clicking This Computer \ Properties or \ Manage. Vista is pretty confusing to me. I don't see a single reason why MS moved / separated so many settings all over Vista. Some time ago I needed to test headphone output so I disabled loudspeakers(wasn't set as default when I plugged in headphones). I spent good hour looking where to enable loudpseakers again. I run through various volume settings, device manager - until I accidentaly right clicked and displayed context menu where I didn't expect it...at last...
    That's why I'm looking forward to #7. I hope they organized it a bit better than vista.
  15. GoodBytes
    20 Jan 2007
    OpenGL performance cannot be calculated due to the lack of official and optimized and final version of Windows 7. So such result would be irrelevant. It might be faster, but when the final version is out of Windows 7 and the dirvers it might be worst, like it could be the reverse scenario.
    Windows 7 BETA is not supposed to be your trial version of Windows 7.
  16. GoodBytes
    20 Jan 2007
    No miracles here, but it's sightly more ""organized"". I actually think that Vista was more organized than XP, but ok...
    What you can do now in Windows 7 is that you can serach for an option.
    For example, if you type "Mouse", you get stuff like:
    "Mouse settings"
    "Change how the mouse looks"
    "Change how the mouse moves"
    and so on for about all the options you can find inside the mouse setting panel.
    What I really like about windows 7 is that it's the Windows with the most consistent layout since Windows 95. It's not perfect, but it's miles ahead of XP and improved over Vista.
  17. wyx087
    wyx087 Multimodder
    15 Aug 2007
    so what's topping you simply press START and type in the stuff you want?
    start -> "mouse" gives me mouse options
    start -> "sound" for sound options
    i go to university lab computers, and i am lost. XP's so stupid way of launching stuff made my work efficiency so low, it's mostly searching for programs/files. at home, on my Vista machine, START -> "whatever-i-want" will ALWAYS come up with the stuff i want.
    Win7 will only take after Vista, it will never be a modified XP, and it should never be viewed such a way. if you are familiar with XP and hate Vista (for reasons beyond my understanding) stick with XP, because 7 will only make you remember it's Vista.
  18. bubsterboo
    24 Jan 2006
    Obviously I understand that. This thread is about Windows 7 Beta performance. So I'm interested to see how Windows 7 BETA performs in relation to Windows Vista with OpenGL. That's a fair Question.
  19. Kúsař
    23 Apr 2008
    But I'll have to upgrade OS sooner or later(there's no DX10 in XP) and from what I have read #7 will give me more control and - judging by screenshots - it has better layout than vista.
    The reason why I don't like vista surely isn't beyond your understanding :) - I just don't like getting used to vastly changed layout.
    These finesses like start->anything sounds really cool but I didn't even know it's there. In fact if they have kept the same layout in Vista I'd be delighted with it and I'd learn these new "start->anything" finesses over time.
  20. wyx087
    wyx087 Multimodder
    15 Aug 2007
    let me get this straight, Win7 interface is based on Vista with changes makes it look more like Mac OSX rather than XP. and you prefer the layout of 7.
    the fact you didn't know quick search was there is just a case of seeing all the bad reputation. Vista is a perfectly fine OS on its own, there is no reason to look down on Vista. besides, benchmarks have shown very little performance gain from Vista to 7. and after SP1, Vista performs almost the same as XP anyway, so the performance arguement has gone out of the window.
    bottom line is that your post shows distinct sign of just hearing about the bad reputation. all im saying is that give it a try and you'll get use to it, it's far easier to get use to comparing the the new Win7 task bar.
Tags: Add Tags
