Modding First Mod Attempt: Punisher
Discussion in 'Modding' started by xrob, 31 Dec 2005.
  1. xrob
    xrob What's a Dremel?
    31 Dec 2005
  2. xrob
    31 Dec 2005
  3. CREDO
    CREDO What's a Dremel?
    18 Jul 2004
    Have you sealed the sanding with a coat of something?
    shes going to rust..
  4. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    yea, that metal may look good now, but even in the best enviroments that thing will rust, then it willl just look fugly, u should look into sealing that up, the effect looks promising, sometimes the best mods turn out exactly how they were not planned to go, after that its just perfecting the proccess,
    a quick google search turned up this, its not the 120mm version, however you could always use one for a template and make your own
    http://www.xpcgear.com/80mpg.html
  5. xrob
    31 Dec 2005
  6. mattthegamer463
    26 Nov 2004
    i think they thought you sanded all the paint off the case and that its bare metal, but your saying its painted. if its painted your fine, if its bare metal then youll need to put a coat of something on it.
    also, how is there a front PCI slot on your case?
  7. cool_dude
    cool_dude Minimodder
    26 Aug 2004
    Looks good, if you would want a polished look, you could work your way up to higher grit paper. :)
    Also how the hell is aluminium going to rust when there is no water there? The way you lot are saying it, is as if it decomposes. (sp?)
    The front pci slot is already there when you buy the case.
    c_d
  8. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    there is moisture in the air. you leave untreated meatl lying around (even indoors) then it will start to rust.
  9. MonkeySpank
    MonkeySpank Banned
    10 Aug 2005
    mmmmm... I agree
    Steel: Will rust in a matter of SECONDS... ever wash an engine block in a parts washer, and take an air-nozzle off a compressor to it? It turns to rust in a matter of SECONDS.
    Alumimum: Will *not* rust, but will Oxodize(Corrodes). It resembles "chalky powder" that comes off it. Oxidizing aluminum only occurs from things IN the water, salt, or things like that. Straight (pure) water won't oxodize aluminium (to my knowledge).
  10. mattthegamer463
    26 Nov 2004
    but is it affected by normal air in a house? thats all that really matters. will it rust or corrode whilst lying under his desk?
  11. MonkeySpank
    MonkeySpank Banned
    10 Aug 2005
    Nope it wont, I was just replying to what someone said before that it will rust:)
  12. Pookeyhead
    30 Jan 2004
    Eventually, yes it will, as the air is never pure.. it always contains oxidants, moisture, and if you live near the sea, quite a lot of salt. Not sure if that was originally a steel case, or alloy, but if alloy, you've just sanded off the anodising, so you're got bare alluminium now. It will dull and tarnish eventually.
    I'd carry on sanding it, but keep your stroked in one direction per panel... that way it won't look like work in progress, even when it's finished. Once done, you could give it a light coat of clear laquer to stop it oxidizing... or maybe get it anodized.
    It's not THAT difficult to do your own actually. Just Google anodising... there are loads of tutorials out there. Just seem to remember you have to use acids, which can be a little nasty, and if you're under 18 or so, you may find people reluctant to sell to you.
