First Project Posting - Project Power User
Discussion in 'Project Logs' started by luvbug, 4 Apr 2004.
  1. luvbug
    luvbug What's a Dremel?
    22 Sep 2003
    I've been here almost a year (I think) and lurked some time before that, added my 2¢ a few times here and there, but never really had a project to post. Well, I've decided to change that and start a project.
    I got this case about 5**½ years ago, when I was kinda new to computers. I bought it from a friend and he accepted payments, so I had nothing to lose really. When I got it, it had 2 CDROM drives, 2 CDRW's, and 2 Floppies. (Don't ask me why, I just thought it was cool to have that much stuff in one case.) :D A P3 500Mhz with 1.5gb SDRAM, a Quantum Fireball 14.4gb hdd, an ATI All In Wonder Rage 2 (TV tuner), and it came with a printer, monitor, mouse, keyboard, speakers, and color flatbed scanner for $2,000.00. I couldn't really pass it up.
    Of course, in that 5 years, everything has been replaced except the hard drive and the 1.5GB SDRAM..that comes in handy!
    Enough with the history, here's a picture of this monster
    Then I bought some cool Antec Cobra Cables to make it a little neater
    Added a piece of smoked plexiglass and a couple red CCFL's
    Well, now I've got 6 hard drives, dvdrw and cdrw, and added another 250watt power supply and lighted fan to the mix. (don't know why I have an extra fan, but it looked neat) As you can expect, I have one helluva tangle of wires and that's what I'm going to fix.
    • make a custom channel or possibly use pipe (conduit or copper)
    • replace the standard molex connectors with 90° lighted connectors
    • combine the power supplies into one housing and add lights - maybe LED's
    • put the case cover back on and add a smoked plexi window
    Any and all ideas and/or thoughts are appreciated. (Unless you think I'm an idiot, in which case I don't care! :))
    Thanks for looking,
    luvbug
  2. richman
    richman What's a Dremel?
    17 Sep 2003
    After browsing these forums for some time i have seen plenty of ideas that can be combined into cases, this case has lots of potential you could do the usual Window, Blow hole ect a paint job is needed have a look at other peoples logs and that should help you to get ideas
    Richman
  3. HQ08-Modder
    HQ08-Modder What's a Dremel?
    14 Nov 2003
    Red X syndrome.
  4. luvbug
    22 Sep 2003
    They all show up for me
  5. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    me 2
    think it is very cool mate
    Funny way to angle a fan tho, lol
  6. luvbug
    22 Sep 2003
    Plastic cable ties are "all the rage" nowadays..lol, doncha think?
  7. Sparrowhawk
    Sparrowhawk Wetsander
    14 Feb 2004
    Wow... that's definatly one battleship behemeth barger of a case! :rock:
    /me likes
    Definatly a load of potential there, mate! :dremel:
  8. TMM
    TMM Modder
    12 Jan 2004
    nice case. i <3 massive cases, but my dad won't let me get anything bigger than my full tower Antec (every time i get a new (bigger) case i have to mod my desk to fit it :D :lol:)
    that must be fun to take to lans :p i just got back from a massive lan (300+ players, went for 28hours) and slept for 14 hours when i got back :eeek:
    while i was there i got some uv fans and uv ccfls. UV stuff looks so much better then just leds and colored CCFLs. you should try some UV red stuff to go with your theme! :thumb:
    edit: also try to get those cables out of the way of your motherboard. i know they are rounded and looks alot better than non-rounded, but try them up out of the way adn im sure it will looks better!
    may i ask what specs your computer is now :) im guessing athlon.....
  9. luvbug
    22 Sep 2003
    LOL, this bad boy doesn't go anywhere, it sits on the desk cause it's too big to sit under it. I do too much dvd and cd burning to have it sitting out of the way.
    I'm actually thinking of just doing everything in red, black, and copper (actual metal, not paint) Maybe add some chromed parts into the mix and paint the metal of the cage with automotive paint. I know the beige HAS to go!
    luvbug
  10. TMM
    TMM Modder
    12 Jan 2004
    OOO me dumb, i just saw your sig LOL!!!!! thats what being awake for too long gets you
    :blush:
    remember if you use bare copper, treat it with clear coat other wise it will go dark ;)
  11. Father-Time
    Father-Time Minimodder
    23 Feb 2004
    At the top of that HUGE case there is load of potential for watercooling madness, man it could take a huge res, rad and the pump in that area above the psu.
    A case that size has great potential, good luck. I would also stealthyour wires with braiding :thumb:
    FT
  12. luvbug
    22 Sep 2003
    hm.... water cooling....... I think that's one hell of an idea! I'll need to make my own blocks though. What materials do you suggest? Acrylic/copper, acrylic/alluminium? I think if I'm going with copper and chrome, I should use acrylic/copper.
    luvbug
  13. Father-Time
    23 Feb 2004
    Yeah acrylic/copper would be good, also look out for some Lucite, i think it is tougher and less easy to scratch, however it still cracks as i have found out.
    BTW, i would not attempt my own water bloocks, never been that good with my hands. :blush:
    Good luck if you give a go Luvbug :clap:
    .....further thought the matter would be to keep in with your theme, copper/copper :hip: Polished of course :clap:
  14. luvbug
    22 Sep 2003
    I do have a question for the cooling gurus: With a HUGE res, is a radiator needed? What if I used a piezzo cooler on the res instead? A peltier cooler, if you will. Can I get away with not having a radiator with fans on it? :confused: My system runs at 102° F as it sits right now, so heat isn't a big problem in this big case. I know I'll have to use fans to move the heat away that the peltier creates, but it should be nothing like a 80mm fan strapped to a radiator....
    Let me know what you think.
    luvbug
  15. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    The simple answer: no.
    The long and comeplex answer: maybe.
    Pelts are expencive and require a lot of power to run. The types of pelts you would be needing to cool a res would put out so much heat, you would more than likely require a seprate watercooling loop with a rad to remove the heat.
    Just bite the bullet and get a rad and a couple quiet fans, imo it's the way to go ;)
  16. NzC
    NzC What's a Dremel?
    7 Sep 2003
    I agree go with the fans, but as you said an 80mm fan would be kinda noisy, so get a 120mm radiator and a 120mm stealth fan on 7v. That will be nearly silent! (you could also have a switch so that you can switch between 7 and 12v. Will be keeping my eye on this (big cases are awesome!)
  17. kill_me_quick
    kill_me_quick Big and Blue
    7 Jan 2004
    Or you could get a twin 120mm rad and two 120mm fans, with a very low dBa and a reasonable flow rate. Then you could 7v them or keep them at 12v and see how it goes. love the case so far though. Nexus fan is 22.8 dB at 12v, nice and silent. Even less on 7v
    Were you thinking about going black. Black with either pink or red would go well. Well thats my opinion
  18. luvbug
    22 Sep 2003
    You're right, I should just bite the bullet and deal with a 'quiet' fan. I haven't decided on a rad or res placement yet, but I've started work on the waterblock for the cpu.
    VERY MINOR UPDATE
    I got some freebie scrap piece of copper and some galvanized conduit
    I'm using dimensions from a spare AMD cpu cooler I had
    I dismantled the cpu cooler and took measurements of width, depth, and thickness.
    Everything is within a few thousands of an inch, except the thickness, its much thicker then the thinnest part of the aluminum AMD heatsink. I can live with that though. :)
    I'll be back with some more pics of the actual block making process.
    luvbug
  19. luvbug
    22 Sep 2003
    Yes, I know I'm slow....lol.
    Another small update
    Unfortunately, I didn't have any metal blades for my jigsaw, so I had to resort to a hacksaw to do my cuts.
    Of course, I got a pretty rough cut, so had to file the edges down.
    Pretty square cut for a hacksaw I think:
    After filing and sanding, I got down to lapping the bottom with 1500 grit wet/dry sandpaper (I may still hit this a few more times, I'm not completely satisfied with it yet.)
    Here's a couple more shots of the reflective surface of the bottome of the block -
    And a last shot with the hose and fittings I'm going to be using with this setup.
    As you might have guessed, I'm not going to use barbs or hose clamps on this setup. I'd rather it be sleek and easy on the eye. these fittings are water proof and require no tools to secure or remove the tubing. No tools = a good thing.
    I know I haven't shown you the business side of the water block yet, and I'm sure you're wanting to see what it looks like... be patient...lol.
    I also decided to go with my original idea of NOT having a conventional res/rad/fan setup. I'm going with a VERY large res and that's all. No radiator and no annoying fans. :idea: I'll reveal this idea as well, when the times comes.
    So until my next update, please let me know your thoughts, comments, concerns, questions.
    luvbug :dremel:
  20. technomancer
    technomancer What's a Dremel?
    2 Apr 2004
    You need to have some form of radiator to dissipate heat in the watercooling system. You can get away with a passive radiator, but just having a large reservoir will not work unless you're only going to run your pc for short periods. Otherwise the fluid in your system will heat up over time.
    Unless of course you're talking about using a swimming pool or something similar for a res. :D
