Planning First scratch built case
Discussion in 'Modding' started by DoctorWho05, 27 Apr 2011.
  1. DoctorWho05
    DoctorWho05 What's a Dremel?
    11 Jun 2007
    Hey gang
    OK so I've been having this idea in my head for my first computer case build. It definitely won't be my first computer build, but I saw all the craftsmanship on here and I wanted to have a go. Since I am not well=versed as some in the art of Sketchup, to get the concept down of what I wanted to convey, the drawing is based off a Lian-Li PC-V2010. I scavenged a few parts from another computer, specifically the mobo tray and the rear PCI/ IO frame.
    I took a model of a lian-li PC-V2000 from the depository and added on some paneling which will be covered in a black wood veneer. This panel will be elevated slightly off the main chassis body to allow for accent lighting on the front and top.
    A window will be added, and ventilation for 3x120 rad. I wanted to go with simple and elegant instead of a really wild design. I still feel my design is unique. Hope to hear from you all about what you think!
  2. cchr
    cchr Minimodder
    24 Nov 2010
    In my opinion it still has a few details that need to be sorted out.
    a cover/mask for the dvd drive, maybe some ventilation at the top, power/reset buttons.
    also, because of the fact that you are going to use wood, maybe you should rethink the design of the silver rad grill, it doesn't quite fit in with the concept.
    cheers
    chris
  3. DoctorWho05
    11 Jun 2007
    I'm not worried about ventilation at the top as I plan on have a WC system.
    The silver rad covers were just a temporary thing I plan on doing mesh there or a black cover.
    I definitely will put a cover on the DVD drive, I just didn't feel like getting into that on the model lol
    And I plan on using the vandal resistant buttons with the ring light for power and the dot light for reset.
    I will also include a front panel set either at the bottom or on the top
  4. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    A top exhaust fan could be helpfull to get rid of the hot air kept inside the case. Every single electronic componant (resistor, capacity, memory, chipsets, etc.) is heating up the air. I think a single rear exhaust fan is not enough, plus warm air tends to go up, so top fan could help a lot.
  5. DoctorWho05
    11 Jun 2007
    hey guys, here's an updated version. I added a 120mm exhaust fan to the top, added a couple anti-vandal buttons, swapped to black grills and just did a little tidying up. What do you think? I'm going to start building it not too far from now and so I'll work on a project log when I do actually start working on it.
  6. DoctorWho05
    11 Jun 2007
  7. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    looks really good, though it seems to miss some defining feature that sets it apart...
  8. confusis
    confusis Kiwi-modder
    5 Jan 2006
  9. DoctorWho05
    11 Jun 2007
    I know it's really similar to that one, but it's sort of where I got the general idea. I just wanted to do something a little different compared to it by doing a wood laminate instead of the white. So on mine it'll be all black with wood laminate over the front. The laminate part will be raised out a little to allow for accent lighting behind it and ventilation. On the inside, I'm going to have only the res and the mobo visible with the window to allow a super clean look. There will be a cross (floor) and under that will be my pump/rad/HDD racks. This is my first build and I hope to have it lay the ground work for future builds.
  10. confusis
    5 Jan 2006
    Very nice idea dude, should be a good one
  11. Xtrafresh
    27 Dec 2007
    Intersting choice of materials! That could be the identity-thing i was still missing in the renders... I hope you will show us the real pictures real soon! :)
  12. DoctorWho05
    11 Jun 2007
    My dad ordered some aluminum for me and I have a few pieces cut up already. I'll start taking some pictures when I start doing some more work on it. I also have been trying to think of a different idea for my hard drive bays. I want to have a hot-swappable set up because I may want to add HDDs in the future. I was thinking of making a sort of box and have a fan blow up from the bottom and exhaust from the side. Similar idea as on the Corsair Obsidian 800D only on the bottom. I also like how the drive bays are on the Cosmos. Also does any one know a place where I could find just the backplane boards cheap? Or a site that has the layouts for one to make them?
  13. confusis
    5 Jan 2006
  14. DoctorWho05
    11 Jun 2007
    Thanks confusis. I think that would be perfect! No if only this order of aluminum would get here...
  15. DoctorWho05
    11 Jun 2007
    Oh, and any of you have some ideas of what I could name this thing for when I start the project log?
  16. GuilleAcoustic
    26 Nov 2010
    I'm not good at naming things .... maybe "First build V1" or "Tardis05" :D
