Build Advice First Time Build Black and Blue Phantom
Discussion in 'Hardware' started by danitgeek, 6 Mar 2011.
What Option Should i Get
  1. 2500k and 570
    4 vote(s)
    100.0%
  2. 2600k and 480
    0 vote(s)
    0.0%
  3. cm psu and drive
    0 vote(s)
    0.0%
  4. cm psu and monitor
    0 vote(s)
    0.0%
  5. leave it how it is
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. danitgeek
    danitgeek Designer
    17 Sep 2010
    This a build that should be starting in a week or so featuring sandy bridge.
    Here some specs
    Motherboard: Asus P8P67 LE
    Cpu:Intel Core i7 2600k 3.4GHz Socket 1155 £259.65
    Ram:2x Kingston 4GB (2x2GB) DDR3 1600MHz HyperX Blu Memory Kit CL9 1.65V £74
    Case Bitfenix Survivor Core Case £68.55.58
    Cpu Cooler:Noctua NH-U9B SE2 £38
    Hard Drive:Samsung HD103SJ Spinpoint F3 1TB Hard Drive SATAII £40.
    Psu:Corsair 750W HX Modular PSU £110.10/Antec TruePower New 650W Modular PSU £69.99
    Monitor:philips 232E2SB Full HD TFT LCD 23" DVI-D Monitor £124.98
    Gpu:Asus GTX480 NVIDIA Graphics Card - 1536MB £194/PNY GTX570 £250
    Os:Mac Osx Snow Leopard
    Total With Shipping = £1030/£1035
    Main Uses:
    -Cinema 4d
    -Google Sketchup
    -Kerkythea
    -Flash
    -Dreamweaver
    Other Uses
    -Social Networking
    -Youtube
    -Full Hd Movies
    -Folding From Time to Time
    Suggestions No problem Since this is my first build.My Limit is £1025.I was also wondering if it possible to put mac osx on this?:thumb:
    I dont pay the bills and game performance doesn't really matter
    __________________
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I'd persomally go for a better PSU, as CM ones are a mixed bag. Go for a Corsair one instead :)
  3. Bartaggio
    Bartaggio Minimodder
    3 Apr 2010
    I'd add some more RAM since you're doing 3d modelling, those programs like alot of RAM.
    And, any reason why you're choosing a 480 over a 5xx?
    As for the OS X, I don't think it should be a problem to install it with the right tools.
  4. danitgeek
    danitgeek Designer
    17 Sep 2010
    Not really i just thought that th nvidia render in cinema 4d/rendering better them ati
  5. donok
    donok Every Little Helps .....
    16 Feb 2011
    5 series nvidia card
    8gb ram for a little more ££
    Corsair psu a deffo
    As your using graphics apps you might need 2tb hdd and it's only £20 more.
    Then in future you could get an ssd
  6. donok
    16 Feb 2011
    Your right nvidia are better then ago at 3d rendering. But the 5xx series cards are alot better in performance, noise and power consumption
  7. danitgeek
    danitgeek Designer
    17 Sep 2010
    I should of have mentioned that i can spend even a bit more than 1020 since the money comes from my parents
  8. donok
    16 Feb 2011
    Also that monitor is 1920x1080
    You'd be better off with a 1920x1200 as the vertical pixels help with image viewin and editing
    16:9 v 16:10 aspect ratio
  9. danitgeek
    danitgeek Designer
    17 Sep 2010
    By Preformance do you mean gaming beacuse i dont really game as well as pay the power bills
  10. KidMod-Southpaw
    28 Sep 2010
    Get a gtx 580 as they have much better tesselation than the 400 series- this will help with rendering. Also, double your ram to 8gb, prices of DDR3 are so low that it shouldn't be a problem.
  11. numanoid
    numanoid Minimodder
    26 Apr 2009
    where can i get that 8gb hyper x blue ddr3 dual ch for £74
    thanks
  12. danitgeek
    danitgeek Designer
    17 Sep 2010
    ebuyer but they will be 4x4gb
  13. danitgeek
    danitgeek Designer
    17 Sep 2010
    Changes Corsair Psu Bitfenix Case and A noctua u12p Cpu Cooler and 2 of 2x4gb kits
  14. danitgeek
    danitgeek Designer
    17 Sep 2010
    Im not sure a about spending that much money for a psu is coolermaster psu realy that bad or any other out there for less beacuase i would rather spend that money on drive or a better monitor but since im not the expert im asking you people in bit tech commounity
  15. mucgoo
    mucgoo Minimodder
    9 Dec 2010
  16. danitgeek
    danitgeek Designer
    17 Sep 2010
    Since people are saying 5xxx series are better i changed the gpu to XFX HD 5870
  17. murraynt
    murraynt Modder
    6 Jun 2009
    An Antec 650Watt true power will be enough for the 570GTX if you get it. That saves 40 pounds.
    8Gb is a must really in a rig like that. Also 74 pounds for 4gb of ram is pretty expensive. I got my 8gb of corsair for 80 I think it was.
    The HSF is overkill. Them Sandybridge chips run very cool. Look at something like the Geild Tranquillo
    Not a fan of the case personally but if you like it that is all that matters. Before you buy have a look at the Fractal R3. A slick rendering machine need a slick case.
    I don't know how mac will run with that kit as I have no clue about mac but i presume since you specked it will be ok.
  18. Bloody_Pete
    11 Aug 2008
    By 5 series, they mean a 570/580 not a 5870 :)
    I've read many mixed reviews of CM PSU's, some are ok, in a CPC mega test last year both failed horribly. Either way, CM PSU's are annoyingly loud.
  19. danitgeek
    danitgeek Designer
    17 Sep 2010
    Ups simple mistake adding extra letters sorry the only one i can afford is the 560 would this be better than a gtx 480??
  20. danitgeek
    danitgeek Designer
    17 Sep 2010
    Actually thats 2x4gb kits x2 i should make that clear sorry it my fualt for puting it at the end ok hmm i will try with the smaller noctua them
