Build Advice First time build for c. ₤1000, max ₤1200. Advice need on spec.
Discussion in 'Hardware' started by GinZ, 13 Jun 2010.
  1. GinZ
    GinZ What's a Dremel?
    13 Jun 2010
    Budget: approx ₤1000, max ₤1200
    Main uses of intended build: Home Theatre to watch online shows in high quality and maybe with TV-tuner and PVR (already have LCDTV 37”, AV receiver Onkyo TX-SR606 and 5.1 quality surround sound), heavy Excel number crunching, strategy gaming (possibly more), all round usage and I like to have many windows and programs open at the same time.
    Parts required: Everything including monitor, keyboard, mouse, maybe tv tuner if recommended. OS needed too, prob Win7 Pro 64 bit. Which OS is best?
    Previous build information (list details of parts): only have a laptop at present
    Monitor resolution: already have a LCD 1080p LCD tv, probably would like to get a small (approx 19”) monitor too
    Storage requirements: unsure but probably at least 1TB, maybe 2x1TB in raid (would like to learn about it). Like the look of those SSDs for idea of putting my OS on it. Is that too expensive however?
    will you be overclocking: yes. Would like to learn.
    Any motherboard requirements (no. of USB, Xfire/SLI, fan headers): USB3.0, SATAIII, maybe Xfire/SLI if it’s worth it, at least several USBs but don’t know how many needed if this helps with future proofing?
    Extra information about desired system:
    • would like it to be quiet but doesn’t have to be silent.
    • Generally as a PC to hook up to my current audio-visual experience and use the PC to do everything on.
    • Also have PS3 and Xbox360 and if I could somehow bring these into the equation it would be cool too.
    • Case: Lian Li PC-B25F. Pics show it would fit in nicely with current AV setup. Alternatives for sleek, minimalist with a little lighting (only a little mind you) and maybe a window would be welcome. Especially if they’re cheaper.
    • Am doing all this to learn as much as possible about computing (have loved the reading over the last few days :clap: ) whilst wanting good value.
    • Wifi if possible
    • TV tuner if it’s worth or at least to use PC to record stuff from my LCDTV (has DVB tuner)
    What's better to go with: Intel or AMD? what's better for future proofing or meaning a cheaper upgrade next time round?
    can't wait for suggestions!
    thanks, GinZ
  2. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    "What's better to go with: Intel or AMD?"
    That's one question you DO NOT ask, it attracts all the wrong sort of people (but I prefer Intel personally)
    Welcome to bit-tech
    Also, is that Pounds or Euros?
  3. chimeradog
    chimeradog What's a Dremel?
    1 Jun 2010
    if you go more on gaming and want to save on $...i recommend AMD...but invest in a good aftermarket cooler to prevent unwanted trouble
  4. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I'm a Intel fan, AMD just doesn't cut it anymore. Do great GPU's though :)
    I assume the TV has HDMI??
    I think an i5 setup would do you best, as I don't think your budget would stretch to a i7.
    If noones specced you up when I return later I'll do it :)
  5. Telltale Boy
    Telltale Boy Designated CPC Jetwhore
    3 May 2010
    I think i've managed to include everything:
    £636.31 + £537.67 = £1,173.98
    I reckon this is about the best build you can get for your budget.
  6. murraynt
    murraynt Modder
    6 Jun 2009
    I think i5 aswell but i would not go for the lian li case instead i would go for the Fractal R2 as its alot cheaper and still excellent build quality
    http://www.scan.co.uk/Products/Frac...oise-Absorbing-x10-Bay-ATX-Case-inc-Front-I-O
    Review from bit-tech:
    http://www.bit-tech.net/hardware/2010/01/15/fractal-design-r2-case-review/1
    I would go for Geild tranquillo cooler
    http://www.scan.co.uk/Products/Geli...l-S775-1366-1156-AMD-754-939-940-AM2-AM2plus-
    Bit-Tech Review:
    http://www.bit-tech.net/hardware/2010/01/20/gelid-tranquillo-cpu-cooler-review/1
    This would make a very powerfull quite pc
  7. GinZ
    13 Jun 2010
    Hi all, thanks for all in the input
    This is a learning experience. I'd prefer to go as best value/performance and then upgrade things going along. This will in theory help me keep value/performance and also help me cement my new knowledge by the upgrading experience and the reading I'll do at the time.
    Great, first post and already I've brought up a no-go subject.
    thanks for the warning, bigsharn. My budget (loose one) is in pounds.
    Gaming? I will only want strategy games or adventure games. I have a PS3 and Xbox for FPSs.
    My TV does indeed have hdmi as does my AV Onkyo 606 receiver.
    Keyboard and mouse - forgot to state they must be wireless as would also like to use the keyboard (and mouse) whilst sitting at a distance from the 37" LCDTV. I have a mega cheapie wired keyboard and wired mouse alreadya, but they're not fun to use (the mouse doesn't have a scroll button!)
    I've looked at the Fractal case already and considerably good-lookig but just a little too plain for me. tis a very good suggestion but, unfortunately for my bank balance, I think I love the blue ring of wonderment on the Lian Li PC-B25F. If it had a version with a side window I prob woulda gone for that :baby:
    GPU: am happy to get just what is needed rather than the best for my budget. ₤320 feels a lot for outlay. I would be happy to upgrade as I go. what would sort me just for HD playing and strategy gaming. However, is the 5870 a better investment to get best value for money for my usage and to cover the need to upgrade soon?
    Thanks, Telltale boy for the specs. I look them up and consider.
    keep the advice coming :thumb:
  8. Telltale Boy
    3 May 2010
    You'd probaby be fine going for the 5850 then which is about £100 cheaper & offers better value.
    Also that RAM kit is supposed to be 4GB, not 6GB (6GB is really only for i7 builds), I must have clicked on the wrong one.
    That'll save you about £150 on the build.
  9. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
  10. murraynt
    murraynt Modder
    6 Jun 2009
  11. Fingers66
    30 Apr 2010
  12. lp rob1
    lp rob1 Modder
    14 Jun 2010
    Go for a 5850 and try to make the leap to i7. The i7 930 is probably the best for performance/value.
  13. murraynt
    murraynt Modder
    6 Jun 2009
  14. Fingers66
    30 Apr 2010
  15. murraynt
    murraynt Modder
    6 Jun 2009
    Just had an accident.It looks so sleek.you realy need to see these cases in person to appreciate the build quality, Touch.They may look very plain on the internet but when get your hands on one in real life you really see how stylish and modern they really are, kinda like an ipod touch
  16. Fingers66
    30 Apr 2010
    A very wise person on this forum posted that it is easier to get a silent case and add extra fans for cooling performance than to get a great cooling case and try and to make it silent...
    If I could find the thread I would credit that poster.
  17. GinZ
    13 Jun 2010
    Hi all,
    thanks for all the additional input.
    I’ve added some of your info and put together a list to build either an AMD system or an Intel one. Please give me your views:
    Items common to both potential builds:
    Case:
    Lian Li PC-B25F - ₤134
    http://www.scan.co.uk/Products/Lian-Li-PC-B25FB-Black-Mid-Tower-Aluminum-Case-w-o-PSU
    or
    very tempted by this, but extra ₤40 on top?!
    Lian Li PC-B25F with window – ₤171
    http://www.scan.co.uk/Products/Lian-Li-B25FWB-Black-Midi-Tower-Case-With-Window-w-o-psu
    GPU: options: which of these most suitable for achieving good quality HD viewing and strategy gaming whilst being the best value?
    HD5850 -
    HD-585X-ZAFV - 1GB XFX HD5850, PCI-E 2.1, 4000MHz GDDR5, GPU 725MHz, 1440Cores, DP/ DVI/ HDMI, Aliens vs Predator - ₤235
    http://www.scan.co.uk/product.aspx?ProductId=35398
    or
    HD 5850 Gigabyte ATI Radeon HD 5850 1GB OC PCI- E 2.1(16) GDDR5 – 235
    http://www.microdirect.co.uk/Home/Product/46611/Gigabyte-ATI-Radeon-HD-5850-1GB-OC-PCI--E-2-1-16-
    are double fans a good thing for noise or not?
    Or
    Asus Radeon HD5850 1GB PCI-Express Graphics Card - ₤225
    http://www.misco.co.uk/applications/SearchTools/item-details.asp?EdpNo=421497&CatId=2697
    or
    HD5830
    XFX ATI Radeon HD 5830 "AVP Edition" 1024MB GDDR5 PCI-Express Graphics Card – ₤165
    http://www.aria.co.uk/SuperSpecials...R5+PCI-Express+Graphics+Card+?productId=40295
    or
    HD5770 - c. ₤123
    SAPPHIRE TECHNOLOGY Radeon HD 5770 - 1 GB GDDR5 - PCI-Express 2.0 (11163-02-20R)
    http://www.pixmania.co.uk/uk/uk/4122063/art/sapphire-technology/radeon-hd-5770-1-gb-gddr5.html
    RAM:
    G-Skill 4GB 1600 CL7 – ₤102
    http://www.ebuyer.com/product/180490
    OS:
    Windows 7 Home Edition 64 bit – ₤78
    Optical drive:
    Samsung Black 2X SH-S223B – ₤16
    https://www.aria.co.uk/Products/Com...al+DVD±RW+SATA+Drive+-+Black+?productId=31918
    Would I benefit having a BD player or writer instead? Bear in mind I have a PS3 for BD already.
    HDD:
    Samsung Spinpoint F3 (HD103SJ) x 2 = ₤47 x 2 = ₤94
    http://www.aria.co.uk/SuperSpecials...+1TB+SATA-II+3.5"+Hard+Drive+?productId=37726
    Case Fan(s): do I need more than one?
    Nexus Real Silent 120mm Fan with PWM control – ₤10
    http://www.aria.co.uk/Products/Comp...t+120mm+Fan+with+PWM+control+?productId=30573
    and/or
    Nexus Real Silent 120mm Case Fan – ₤10
    http://www.aria.co.uk/Products/Comp...s+Real+Silent+120mm+Case+Fan+?productId=28883
    or
    Titan TTC-NK85TZ Fenrir CPU Cooler – ₤30
    http://www.scan.co.uk/Product.aspx?WebProductID=1000983&source=froogle
    why is the Titan so much more expensive? Is it worth it?
    Monitor: options
    Viewsonic VX2260WM Full HD 22" TFT Monitor 1920x1080 20,000:1 (dynamic) 300cd/m2 2ms VGA/DVI-D/HDMI Black – ₤148
    http://www.ebuyer.com/product/151336
    or
    Samsung Lavendar P2250 22" LCD Monitor 16:9 Full HD 1920x1080 300cd/m2 50000:1 Dynamic 2ms VGA/DVI Rose Black 3 Year Onsite SWAP Warranty – ₤139
    http://www.ebuyer.com/product/164043
    or
    LG W2261VP 22' LCD Monitor 16:9 DVI HDMI Black – ₤133
    http://www.amazon.co.uk/product-rev..._next_2?ie=UTF8&showViewpoints=0&pageNumber=2
    or
    Benq G2222HDL – ₤135
    http://www.ebuyer.com/product/177132
    PSU: options
    True Power New 750 - 750W Antec Truepower New PSU, Modular, 120mm PWM Fan, 80+ Bronze – ₤93
    http://www.scan.co.uk/Products/750W-Antec-Truepower-New-PSU-Modular-120mm-PWM-Fan-80plus-Bronze
    or, maybe I could get the blue fan led version if I buy the case with a window
    Blue True Power New 750 - 750W Antec Truepower New PSU, Modular, 120mm PWM Fan, 80+ Bronze – ₤104
    http://www.ebuyer.com/product/159923
    Common stuff subtotals: min ₤783 : max ₤978
    And now the AMD CPU and Mobo:
    AMD CPU:
    Phenom II X4 955 – ₤120
    http://www.aria.co.uk/SuperSpecials...re+955+Black+Edition+125W+C3+?productId=39930
    AMD Mobo:
    ASUS M4A89GTD PRO/USB3 890GX – ₤112
    http://www.ebuyer.com/product/198314
    AMD CPU+Mobo Subtotal: ₤232
    Or shall I get the i5 750?
    Intel CPU and mobo:
    Intel CPU:
    Intel Core i5 750 2.66GHz (Lynnfield) (Socket LGA1156) - Retail + Napoleon Total War [BX80605I5750] - ₤157
    http://www.overclockers.co.uk/showproduct.php?prodid=CP-299-IN
    Intel Mobo:
    Asus P7P55D-E, Intel P55 Express, S1156, PCI-E 2.0 (x16), DDR3 2200(OC), SATA 6Gb/s, SATA RAID, ATX – ₤129
    http://www.scan.co.uk/Products/Asus...-(x16)-DDR3-2200(OC)-SATA-6Gb-s-SATA-RAID-ATX
    or
    ASUS P7H55D-M EVO Socket 1156 i5/i7 VGA HDMI Out 8 Channel Audio MATX Motherboard – ₤102
    http://www.ebuyer.com/product/190025
    What’s the difference between these Intel mobos? If none, why the ₤27 difference?
    Intel CPU + Mobo subtotal: max ₤286 : min ₤259
    AMD build total: max ₤1210
    Intel build total: max ₤1264
    So guys, which build would you go for and why?
    Any other suggestions are also very welcome.
    Maybe how I could make this build cheaper? (when I began my idea to build my approx budget was ₤600!)
    Or have I missed any important bits out?
    still reading?! thanks for doing so
    Hmm,quite a long post/essay - please do let me know if these are inappropriately long.
    GinZ
