Build Advice First-time builder
Discussion in 'Hardware' started by jsty3105, 22 Jul 2010.
  1. jsty3105
    jsty3105 What's a Dremel?
    22 Jul 2010
    Based off the comments so far, I'd adapt my build to plump down for bagpuss's build but change a few components:
    PSU - OCZ StealthXStream 500W Silent SLI/Crossfire Ready ATX2.2 Power Supply from aria
    Case - CM 335
    Guess Z1-Sapphire ATI Radeon HD 5770 Vapor-X 1024MB GDDR5 PCI-E in the Bargain Basement of Aria (£114.02) would be the best GPU to use for this setup so far. The noise issues of the HD 4890 are too worrying and the only 'quiet' version of that card, the Sapphire, costs about £20 more than this 5770.
    So, to run through the setup again:
    CASE: coolermaster elite 335 £29.95
    PSU: OCZ StealthXStream 500W Silent SLI/Crossfire Ready ATX2.2 £44
    HDD: 500GB Samsung F3 £33.45
    MOBO: MSI 770-C45 £52.64
    GPU: 1GB HD5770 £114.02
    MON: Viewsonic 20" VA2013BW 1600x900 £94.34
    CPU: AMD Athlon 255 £54.78
    RAM: 4GB DDR 1333 Corsair £72.97
    Total = 496.15 (Sweet! A sub-£500 system)
  2. adam_bagpuss
    24 Apr 2009
    the 4890 is quite a bit more powerful than the 5770 though
  3. paisa666
    paisa666 I WILL END YOU!!!
    4 Mar 2009
    Not to bash or anything...
    But sometimes i find dificult explain to myself how a "noise issue" its reason to not buy anything, specialy when its way better.
    I would definely go for the 4890, this ofc taking into account that the games you wanna play are not DX11, so you could have more advantage fron the 4890, its much better than the HD 5770 and it cost the same.
    Ofc there' the issue with the power supply, you would need a bigger one (at leat 650Watts) wich probaly would be a problem for your budget...
  4. registeredlandmine
    registeredlandmine What's a bit-tech?
    19 Jul 2010
    Yay that was me (new to the forum). Another +1 for the 4890, a 4870 is better than a 5770 and the 4890 is better than a 4870, yet the 4890 is cheaper than the 5770, its an easy choice really.
  5. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Well Paisa just hit something straight there, go for the 4890 and I don't think 400W is enough, and I can assure you that when you have the PC set up infront of you the 'noise issue' will explain itself...
    Tbh, the 5770 is more futureproof and quieter and overclocks better making it my choice
  6. Sh0cKeR
    Sh0cKeR a=2(s-ut)/t²
    21 Aug 2009
    500w would be enough to run one 4890 without any problems. Plus, the money saved on the GPU would go to buying a 500w PSU.
  7. KD88
    KD88 Minimodder
    25 Aug 2009
  8. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Don't go with an OCZ PSU, it's not the worst in it's class but is far from the best of its price, for that money a Silverstone Strider will do fine
  9. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Double Post FTL
  10. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Triple Post - Internet connection makes me mad
  11. Cus_de_Sparta65
    Cus_de_Sparta65 "There is no dremel"
    24 Apr 2009
    Aria are only giving a 30 day warranty with that sapphire 5770 so I would personally stay clear of it. It is probably a return someone else had trouble with or something like that as I think it also mentions the box is bust or not the original packaging.
    I was seriously looking at it till I read the small print.:nono:
  12. jsty3105
    22 Jul 2010
    Hmm... still wonder whether it's worth the risk - depending of course on the common reasons for returns to Aria.co.uk. If it's commonly for faulty products, I might skip this choice.
  13. jsty3105
    22 Jul 2010
    Don't find any Striders in that list
  14. memeroot
    memeroot aged and experianced
    31 Oct 2009
    +1 4890
  15. jsty3105
    22 Jul 2010
    I'm getting quite a few votes for the HD 4890 but I don't see it for less than £140...
  16. adam_bagpuss
    24 Apr 2009
    whats price difference between a 1GB 5770 and 1GB 4890 then ?
    can see if its worth it
    oh andyes you'll want the 1GB 5770 not the 512MB as this is muhc slower when your gaming at higher resolutions
  17. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
  18. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    which list :O
  19. adam_bagpuss
    24 Apr 2009
    that is a BARGIN fingers
    id be grabbing that 4890
  20. memeroot
    31 Oct 2009
    or you could go 2nd hand from a reliable source for a 4890
