Watercooling First watercooling order
Discussion in 'Hardware' started by happyhammer7, 10 Jul 2011.
  1. happyhammer7
    happyhammer7 What's a Dremel?
    19 Oct 2009
    Hi guys,
    I am putting together a watercooling solution for my i7-930 CPU. I decided to stick with my corsair 650d as I will only be watercooling the CPU.
    Anyway, I may have done this all wrong so let's have a look. Here are a list of the parts I am looking at buying.
    Watercooling
    EK PSC 1/4" Thread Compression Fitting for 1/2" ID - 3/4" OD Tubing : Silver x6
    XSPC RS Series 240mm Dual Radiator : RS240
    XSPC Dual Bay Reservoir with DDC Pro 10 Pump (Bundle Deal)
    Scythe Gentle Typhoon 120mm Case Fan 1450 RPM : D1225C12B4AP-14 X2
    XSPC 1/2" ID - 3/4" OD (13-19mm) High Flex Tubing : Black
    Primochill ICE Non-Conductive Coolant 32oz : Clear
    XSPC Rasa CPU Waterblock Intel 1366, 1156, 1155, 775 : RASA Black
    I don't think the waterblock comes with a fitting kit, so may need that as well. What do you all think so far? Don't want to spend crazy amounts but very open to advice to maximise cooling potential.
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I assume you've read through my thread? :)
    Looks ok, not sure about that CPU block though... The ports look very close together so you may struggle with those fittings, it's a common problem with many water blocks.
    That non-conductive coolant is a waste of money too. I know what your thinking 'this way if it leaks then it wont kill my system' I'm afraid you've been mislead. Those coolants are non-conductive at first but a couple of weeks in and dust and metal perticles, as well as metal leaching will make them conductive.
  3. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
    don't forget Silver KillCoils Mayhems Biocide...
  4. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Maybe take a look at the EK H3O kits. It comes with a pretty good set of components. The copper block 240 kits are around 160gbp.
  5. happyhammer7
    19 Oct 2009
    Would this be better?
    EK Supreme HF Easy Mount CPU Waterblock Intel 1366, 1156, 1155, 775, AMD AM3, AM2+, AM2 : Copper Acetal
  6. Bloody_Pete
    11 Aug 2008
  7. Big Elf
    23 Apr 2009
  8. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
  9. Bloody_Pete
    11 Aug 2008
    I use a Swifteck Apogee XT, and it's modular so will easily take all fittings :)
  10. penryn 2 hertz
    10 Jun 2010
