Modding First watercooling part made myself
Discussion in 'Modding' started by Fonne, 6 Oct 2012.
  1. Fonne
    Fonne What's a Dremel?
    9 Oct 2010
    This I made yesterday :) .... My first ever produced watercooling part :D
    Its a GPU only TOP, made out of a single POM piece (Made to fit some old cobber bottoms)...
    Made very simple/fast, but its also just a prototype, still some changes to do :)
    Pretty happy about how it look, thinking about that is was just a prototype, and nice go get some experience in doing stuff like it :)
    Have really enjoy making this, hope to make more watercooling / modding parts, would LOVE it :D
  2. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Very sexy Fonne! POM is sooo nice to mill... have a little fetish about that stuff lol
  3. Fonne
    9 Oct 2010
    Thanks :thumb: ... And POM is really lovely to mill, just love to make stuff out of it :D ...
    Has been working with Acrylic, POM, PA6, PHED etc (Plastic) in many year, but the first time I do something like this, and really love it :)
    (Could be nice someday in the future making stuff to the community)
    Its nice to get some practice, since im planning making CPU, Chipset and fullcover to my casebuild ...
    Thanks again :thumb: (And its normal to have that kind of fetish :naughty: - I hope :D)
  4. Fonne
    9 Oct 2010
    This is the next thing im going to mill when there is time ...
    (Drawing from Solidworks)
    A new top so his EK waterblock can fit a Shuttle S775 motherboard that uses a different hole distance (Pretty big differance than normal S775 boards) ...
  5. Editor22
    3 Jan 2009
    Looking forward to the update :D
  6. ShinyAli
    ShinyAli What's a Dremel?
    14 Sep 2012
    Nice work, I don't know much about this material but a quick search shows it's a polymer, could it be used for 3D printing?
    I don't have a lathe/mill but I would like to do some work with this material and as I mainly use hand tools can POM be sawn, filed and drilled, I see you have threaded this piece, can you tap straight into POM or do have to use threaded metal inserts?
    I would like to use this material with aluminium as I think they would make a nice contrast together with shiny ali and the satin finish of POM. :cooldude:
  7. Fonne
    9 Oct 2010
    Me2 :D
    No, you dont use POM when 3D Printing, most small 3D printers use ABS.
    And POM is pretty easy to work with (Sawn, drill) - And you can tap straight into it, no problem ... Its a pretty hard material, so normally I dont use metal inserts, only in softer types of plastic - But its depends of how strong you want it to be ...
  8. Fonne
    9 Oct 2010
    Some other parts made out of POM - From my work ...
  9. that_du^de
    that_du^de give your head a wobble
    29 Nov 2010
    very nice. show some pics of the mill and lathe at work!!
  10. Fonne
    9 Oct 2010
    Will try to show the mill in action next time :)
  11. Editor22
    3 Jan 2009
    is that a 30cm rule in the top picture Fonne?!
  12. Fonne
    9 Oct 2010
    Yeah, its a 30cm ruler in the top picture :)
  13. Editor22
    3 Jan 2009
    Damn that's a big block of POM! and such a great surface finish! you must be running some pretty serious machines :p
  14. Fonne
    9 Oct 2010
    Thanks :thumb:
    The machines im running is not something brand new 5 Axis, but they do the job pretty nice :)
    This was something I was testing yesterday - Its show the size of the Lathe :) (Diameter: 200mm)
    Need to drill from both sides ...
    Is just waiting to get some free time on the machines, so I can start making fun stuff :cooldude:
  15. Editor22
    3 Jan 2009
    God I love POM
  16. Cheapskate
    13 May 2007
    Drilling $200+ worth of delrin just to try something? :nono: NOW you have to turn it into a reservoir.;)
  17. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    what does POM stand for?
  18. mrMonkeyChunks
    mrMonkeyChunks EVGA Cheesecake
    4 Mar 2012
    It's an abbreviation of the plastics full chemical name Polyoxymethylene
  19. disturbed13
    28 Nov 2008
    cool thanks man
    i googled it and got no where
  20. Fonne
    9 Oct 2010
    It will be finished to the customer :) - Got some picture of the part its going to be, hope to show something tomorrow ...
    The CNC program to the next watercooling top (The EK) is also finished, and just waiting to get some free machine time, all sorts of wierd things we are making right now ...
