Other Fish tank owners
Discussion in 'General' started by CrapBag, 2 Oct 2013.
  1. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    We have a simple Aqua one 320 pro fish tank and the light has failed, it just blinks when we turn it on.
    The proper lamps are around £15 but using the code on the lamp itself I have found some other alternatives.
    Would anyone know if these are suitable.?
    The code on the lamp is PL11W 8000K and the one I have found is this
    If this isn't suitable does anyone know a good place to buy one?
  2. samkiller42
    25 Apr 2006
    What are you keeping? If it's for plants, then you want a bulb that's similar to what you have, if it's fish only with plastic plants, then any bulb will do as it's only there for you to see the fish.
    Sam
  3. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    We use live plants that are weighted down but not potted ones.
  4. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    I'd say you are looking for lightbulbs/tubes that have a colour temperature equivalent to daylight, which is 6500k if memory serves...
    A lower temp will be yellow-orange and look nasty, so bright white/blueish will be best to look for, just check the fitting is correct for your set up.
  5. Krikkit
    21 Jan 2003
    If you're keeping fish/plants, you should replace like-for-like really. This one doesn't seem too badly priced. :)
