Modding fitting 2*120 radiators in cm STacker
Discussion in 'Modding' started by Stav_13, 20 May 2006.
  1. Stav_13
    Stav_13 What's a Dremel?
    13 Sep 2004
    hi i have took the plunge and have brought 2* 2*120mm radiators to start my watercooling case for the first time, now when to radiators arrived i (from looking on many project logs on here) belived the radiator would fit in the front of the case. now it is too narrow to fit in so i am wondering if you can get any fitting kits for radiators, i have brought the XSPC rads if that helps. im thinking that i am going to have to make my own fittings at the end of the day but if there are any kits out there it would help so much plus would stop the dremel cutting my fingers :miffed:
    thankyou very much in advance
    Stav
    p.s if there are any project logs outside of this website for stackers fitting radiators please leave link ;)
  2. Silk
    Silk What's a Dremel?
    25 May 2006
