Modding Fitting a LCD display screen res cant get right.
Discussion in 'Modding' started by ronnie-ajw, 24 Sep 2007.
  1. ronnie-ajw
    ronnie-ajw What's a Dremel?
    13 Apr 2006
    Hi all,
    Ive adding a 7" tft-lcd monitor to my system and cannot set the screen res to the correct size which should be 1140x234 :wallbash:. Does anyone know how I go about this as this will be modded into the case.
    Cheers Ronnie.
  2. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    operating system? how is the monitor connected? also, this is not a guide.
  3. ronnie-ajw
    13 Apr 2006
    Operating system is Windows XP pro, connected via the s-video. Have moved to modding.
  4. dragon2309
    dragon2309 techie
    28 Jul 2006
    I might be wrong but i dont think s-video can reach those sorts of resolutions, can it?
  5. rito
    rito What's a Dremel?
    19 Sep 2007
    What kind of video card do you have?
    If you have an Nvidia card you can use the nvidia control panel, to set the resolution to what ever you want.
  6. ronnie-ajw
    13 Apr 2006
    I think it should as I believe its for video (i might be wrong to lol) I have it at 1024/768 but the screen is blurry, if there is a way to get rid off the blirryness please let me know.
    Cheers Ronnie.
  7. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    1140x234 sounds a bit weird. 7" widescreens are normally around 640x3xx or something. try to use a lower rez and work your way up till you find something that looks good. I have seen some screens which use upscaling but the picture looks crap IMO.
  8. One~Zero
    One~Zero What's a Dremel?
    9 Sep 2004
    You can try a program called PowerStrip, which allows you to customize resolutions, refresh, timings, etc. for auxiliary displays. Not sure what your display controller is, but they seem to support quite a few. I don't have any experience with this program, but have heard quite a bit about it. Do a search if you need more detailed info and let us know how it works out.
