Apple Fitting an Airport Extreme card
Discussion in 'Tech Support' started by ElThomsono, 20 Feb 2009.
  1. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    I'm trying to get a eMac to register a wireless card, I've physically installed it but system profiler doesn't detect the card. I've read some stuff online and it appears that sometimes they just don't work :confused:
    Any apple tips I should know? I've reseated the card several times and cleared the PRAM but it's yet to detect the card.
    The only thing I can think of is an air duster for the contacts, think that's worth getting?
    Edit: You do just shove it in and OSX should automatically detect it, right? :worried:
  2. Wopsh
    Wopsh Don't own a Dremel :(
    29 Dec 2008
    I've had a DOA airport extreme before. Be sure you have it right side up and stick the antenna in. If you seated a working card right and have up to date software it will detect automatically.
  3. ElThomsono
    18 Mar 2005
    AFAIK it's 10.3.9, it's not as advanced as 10.4 anyway. Would that cause problems?
