Cooling Fittings Help Please
Discussion in 'Hardware' started by Leeum, 13 Feb 2005.
  1. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    I'm about to order some fittings from Airlines. What i need is 1/2" BSP to 1/2" and 1/4 BSP to 1/2" hose tail barbs in nickel plating. Airlines only sell them to 12mm, will that be ok for 1/2" tubing?
    Another thing, they'll fit if they're BSPT won't they?
    Thanks,
    Leeum
  2. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    12mm is .472 inches. I think it's close enough for government work.
    Knew it cause that's the tubing diameter on my (french) horn.
  3. Leeum
    16 Feb 2004
    :hehe:
    As long as it fits my 1/2" ID tubing that's fine, i'll go ahead and order, thanks mate :D
  4. KayinBlack
    2 Jul 2004
    Glad to help.
    Now if I could just get my stuff fixed, we'd both be happy.
  5. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    What are the 1/4 BSP to 1/4 hose tail barbs for???
  6. Leeum
    16 Feb 2004
    Sorry typo :D The barbs are for my XSPC Radiator and Hydor L30 II.
  7. coolmiester
    31 Dec 2002
    Thought it might of been a typo but then again, thought you might have had something going on that we needed to know about :)
  8. Leeum
    16 Feb 2004
    :hehe: You know if that was going to happen i would've bombarded you and Nexxo with PM's for advice :D
  9. coolmiester
    31 Dec 2002
  10. Leeum
    16 Feb 2004
    Thanks, wounder where i got that idea from :hehe: Can you guess what comes next? My grandad is taking it tomorrow but i'll have to wait until school to use the polishing wheel :blah: Would it come up as good if i hand polish it?
  11. coolmiester
    31 Dec 2002
    First shiny Maze4 i did by hand and it took for ever.........much easier with a polishing wheel believe me!
