Hardware Five LGA1156 coolers tested on Lynnfield
Discussion in 'Article Discussion' started by Sifter3000, 13 Aug 2009.
  1. ciri28
    ciri28 New Member
    16 Jul 2009
    two thoughts
    First, I am relieved to find out that I am not the only person that hates the way most coolers mount. I am certain that there is a secret competition between the designers to see who's cooler can obtain the highest points in three categories, longest to install, most frustrating and most confusing.
    Second, the coolers maybe part of a more sinister plot. Assuming that everyone is busy for an hour* installing their cooler at the same time, an opportunist could take over the world with little resistance or commotion.
    *I am allowing an hour time to wad up the instructions and throw them across the room, stomp on the box and search the internet for new curse words.
  2. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Good detective work :) Yes, the delta Ts are very high, which is why none of the coolers got a good review.
    Although, as the article states, we can't go specifics about the overclock, I can say it's not the maximum overclock for that chip and doesn't require a huge amount of additional voltage. Clearly, the cooler manufacturers still have a lot of work to do.
  3. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    when will we see test results for those boards and the cpus?
  4. Claave
    Claave You Rebel scum
    29 Nov 2008
    When they launch - be patient! :)
  5. HourBeforeDawn
    26 Oct 2006
    really? Intel and the mobo companies have a NDA that last until launch thats unusual
  6. Guest-16
    Guest-16 Guest
    mobo companies are under the same Intel NDA. It's entirely normal and usual ;)
  7. Guest-16
    Guest-16 Guest
    It's the "hackers keyboard" of motherboards.
    All black has been done to death. (Yet I will admit I find it attractive with the subtle grey). It's an uninventive style.
    I won't deny it will be technically fantastic.. if you run liquid or extreme cooling, but for the average consumer it will be no better than the usual suspects.
  8. HourBeforeDawn
    26 Oct 2006
    really huh... that sucks oh well so what was the end of the NDA again for them?
  9. Guest-16
    Guest-16 Guest
    8th Sept.
    Got a loonnnnnnnnnnnnnnng way to go :D
  10. HourBeforeDawn
    26 Oct 2006
    D'oh >.<
  11. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Hmmmm.... just a month. Almost time for another nVidia rebadge then, ain't it?
  12. wyx087
    15 Aug 2007
    a bump on this old thread. sorry. but i wanted to ask:
    when is bolt-through kit for TRUE going to be released? what about a re-newed edition of Corsair H50?
    having played with i7 860 at Asus event, and not under any NDA. i would like to take a stab at guessing the processor speed used:
    3.8Ghz to 4Ghz?
    reason is that you said voltage isn't particularly high, it won't break 3.6 on stoke volts. also, it's 100% load which should yeild higher temperature than x264 encoding, but we used stock cooling, so it should be about the same.
    am i right? pretty sure it's not more than 4Ghz. there's a thermal wall at 4Ghz, at least with stock cooling and Intel TM enabled :p
Tags: Add Tags
