my msn will not open it simply crashes have tried the good old fashioned reboot and an uninstall and reinstall of the program, any ideas people? ty in advance <<<<>>>>> This Problem reported itself as a WLDCore.dll error in event viewer, below is the fix Fix found: go to in registry: HK_CU->Software->Microsoft->MSNMessanger->PerPassportSettings-><number here>->UTL and delete this key* *** make a backup in-case it doesn't work <<<<>>>>
Do you get any errors at all? Event viewer might be a good place to look and see if there's anything thats popped up in there.
Code: Faulting application name: msnmsgr.exe, version: 14.0.8117.416, time stamp: 0x4bc935af Faulting module name: WLDCore.dll, version: 14.0.8117.416, time stamp: 0x4bc93503 Exception code: 0xc0000005 Fault offset: 0x00002ee5 Faulting process id: 0x1240 Faulting application start time: 0x01cb34950b6896cb Faulting application path: C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe Faulting module path: C:\Program Files (x86)\Windows Live\Messenger\WLDCore.dll Report Id: 4c28be6d-a088-11df-950a-a4badb9c4e73 seems to be a .dll error, oh great ¬¬
uninstall live messenger > delete the Windows live messenger directory in program files > run a cleanup program such as ccleaner > reinstall WLM
as stupid as it sounds, make sure you have the right time and date set on your computer. If it's late, messenger won't start.
after doing the first part (removing wlm) run the registry clean up tool in ccleaner then reinstall wlm...
Ok next step I guess is throw it all out of the window...If I can come up with anything better in the mean time I'll let you know
i dont go near the registry often enough to know what to look for so some explaination please mate Edit: just used the guest account (yes that horrible thing) and it works fine on that one so its something on this user profile
Fix found: go to in registry: HK_CU->Software->Microsoft->MSNMessanger->PerPassportSettings-><number here>->UTL and delete this key* *** make a backup in-case it doesn't work, however it does for me, I will also edit this fix into the first post.
