Other Fixing my daughters flat mates pc
Discussion in 'Hardware' started by CrapBag, 22 Sep 2017.
  1. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    My daughters flat mate hasn't used his pc for over a year and a half as it just kept shutting itself down.
    So I offered to look at it for him and as I thought it was the cpu overheating and the thermal cutout kicking in.
    So I look at the cooler that has been fitted to the cpu and seeing as its a hexa core FX 6300 I expected at least to see something with heat pipes but nope bog standard POS stock heat sink which I have now found out is for a sempron chip so woefully inadequate, it also had so little TIM on the heat sink that when I removed it there was zero TIM actually on the chip itself leading me to believe it wasn't even making contact. It was reaching 82c doing very little then shutting down.
    I then quickly realise there is no front intake fan and had already been told there wasn't a fan in the rear when he bought it either, plus both roof fan mounts are empty.
    This is a prebuilt purchased pc with no fans, an incorrect stock fan and to top it all off he has a 7870 gpu in it which if I recall were always rather warm running.
    Pretty crappy I thought.
    Plus is a Corsair 450w psu enough to run this pc happily?
  2. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    Sounds like your typical run-of-the-mill prebuilt stuff.
    That corsair 450W psu is just fine for that spec.
  3. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Its from a fairly well known online pc builder too, who you would think would know better, especially regarding the cooler.
  4. adidan
    25 Mar 2009
    PSU is fine, shocking build though eh. Wrong hsf and no case fans?
  5. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Yup, it may have had one fan in the rear that didn't work though.
  6. adidan
    25 Mar 2009
    I think that may even be worse :)
  7. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    You got a replacement cooler crappy?
  8. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Not at the moment, im currently testing it with an old H80 that's not fully functional and I wouldn't trust for day in day out usage.
    Temps only went upto 32c under prime though with a mental 2000rpm fan running on it lol
  9. mrbungle
    20 Sep 2004
    FX6300 always came with a shitty alloy cooler.
