Graphics Flashing a FX5900 to FX5950ULTRA HELP<===
Discussion in 'Hardware' started by SFOD-D LoneWolf, 30 May 2004.
  1. SFOD-D LoneWolf
    SFOD-D LoneWolf What's a Dremel?? :p
    10 Apr 2004
    As per title.
    I got myself a ASUS V9950 FX5900 and I wan't to change the bios to a FX5950 one, the question is, where can I get a FX5950ULTRA BIOS that will work with my card(so that the Video-out port will work),and will there be a noticable increase in heat.
    I have a ZALMAN ZM80C-HP and a ZM-OP1 on the shelf, will this be enough??
    Cheers,
    Mike
    P.S.
    I know how to swap the BIOS, I just need the BIOS itself....
  2. Mister_Tad
    27 Dec 2002
    go to gainward's ftp site (ftp.gainward.co.uk or something similar to that) and you can get a bios for just about every nvidia card out there
    i found the ultra 1800XP bios to be the best flashing a gainward golden sample 1200XP
    the built in temp probe probably wont give you an increase of heat but i think that is because it compensates with the new bios, so there is a slight increase (voltage increase by about .2v)
  3. SFOD-D LoneWolf
    10 Apr 2004
    hmmm....site does'nt work...........
    Anyways, will the Gainward BIOS work in my ASUS card, so that the TV-out will remain functional?
    Cheers,
    Mike
  4. Mister_Tad
    27 Dec 2002
    hmm
    tried a few of the gainward ftp sites and they all want a user and pass
    wasnt like that a few months back
    since the gainward card has both tv-out and video-in it should be fine with your card.
    mine was fine with video out and in after the flash
    i think most people that were having problem regarding the functionality of the card after the flash were flashing VIVO cards with a bios with only tv-out
    if it doesnt work then you can just flash back
    try to look for the leadtek bios as well, that is another one i had good results with
  5. Gecko
    Gecko What's a Dremel?
    29 Dec 2003
    My leadtek flashed fine, i dont know wether the TV out still work tho, i heard it didnt, but i got my card running stable at 500/1ghz up from 425/700 :D
    Is it wise to flash a card with another manufactueres bios?
  6. Mister_Tad
    27 Dec 2002
    there wont be any poblem flashing with a bios from another manufacturer
    i have tried creative, leadtek, bfg, gainward and asus bioses for a gainward card
    the bigger manufacturers would be the best bioses to use as they are most likely to be updated more frequently though, ie if you grab the most recent gainward 5950 bios it is probably more up to date than the most recent pixelview 5950 bios
    the difference between then performance wise was minimal, so i used the gainward one in the end as it had the VIVO on it
  7. SFOD-D LoneWolf
    10 Apr 2004
    Thanks all
    My ASUS has just the TV-OUT :sigh:
    (but who cares anyways? :rock: )
    I got my hands on a LeadTek, but I would prefer a ASUS BIOS, if anyone has one that is.
    Cheers,
    Mike
  8. keir
    keir S p i t F i r e
    5 Oct 2003
    What would flashing the bios from a FX 5900 to a FX 5900 ultra acctually do?
  9. Mister_Tad
    27 Dec 2002
    relaxes the ram timings slightly to allow a bit more speed on the memory
    but the main thing is that it ups the voltage on the gpu (from 1.35 to 1.5 i think)
  10. SFOD-D LoneWolf
    10 Apr 2004
    Ehem.......to a FX5950ULTRA......
    Cheers,
    Mike
  11. keir
    5 Oct 2003
    so is there any really performance differance?
  12. SFOD-D LoneWolf
    10 Apr 2004
    Sure there will be a boost in performance, the 5950ULTRA has higher clocking afterall....
  13. unclean
    unclean SMP obsessive
    30 Dec 2003
    Hey,
    Tell me what happens with this. I should be getting one if all goes well...
  14. SFOD-D LoneWolf
    10 Apr 2004
    Me again.
    I got all my needed componets, I should flash it within the week, but I need to know if the stock cooler will be enough, or if not, is the Zalman ZM80C-HP with fan enough.
    Cheers,
    Mike
    P.S.
    3DMark tests will ofcourse be posted :)
  15. Mister_Tad
    27 Dec 2002
    stock cooler on mine was fine, but i used a home-brew cooler for 575/1020
  16. SFOD-D LoneWolf
    10 Apr 2004
    Ghetto cooler? :D
    Cheers,
    Mike
  17. Mister_Tad
    27 Dec 2002
  18. SFOD-D LoneWolf
    10 Apr 2004
    Too eXtreme for me :eeek:
    I think I'll stick with the Zalman....
    Cheers,
    Mike
