I'n not sure where this should be going, but I got some daft problem here that I need help with: I have a thing where if u put it next to a speaker, some lights in the pc flash to the beats, it worked perfectly before, until my jinxed friend came round the other day. For some reason when the beats are going, the light just stays on full, not chaning to the beats. But... when i touch the device next to the speakers, and touch the pc case at the same time, everything works perfectly! Any ideas on whats causing the problem?? I cant touch the two things every time I listen to music cant i??
Sounds like he knackered the ground cable, pull the device apart, or fit a small grounding cable between them.
solder a small length of cable to your pc case, and the case of your device. Moving this to modding to get the right attention.
