Flat TV or ordinary TV?
Discussion in 'General' started by getzephyr, 14 Aug 2008.
  1. getzephyr
    getzephyr What's a Dremel?
    14 Mar 2008
    Can anybody explain me how flat TV is having more advantages than an ordinary TV?
  2. Journeyer
    Journeyer Minimodder
    31 Aug 2006
    You really only need to go and get one demonstrated for you; the advantages should then be obvious.
    However, I'll give you five reasons off the top of my head:
    1. Flatscreens take up much less space.
    2. They are far more energy efficient.
    3. They give a more stable and clear picture.
    4. You don't get that high-frequency whine that CRT's give off.
    5. You can get them in HD.
  3. DougEdey
    5 Jul 2005
    Do you mean Flat CRT screen compared to curved CRT or LCD compared to CRT?
  4. Mister_Tad
    27 Dec 2002
    You can get HD CRTs that have a far better picture than LCDs and Plasmas. Unfortunately size and weight constraints mean that you're unlikely to see them any bigger than around 34" - which is likely to weigh around 100kg and have a depth of nearly 3'
  5. Krikkit
    21 Jan 2003
    Yup - we've still not beaten CRT's for out-and-out quality yet, it's just the practical aspect of being able to have a 48" TV that's <6" thick mounted on your wall. :)
  6. profqwerty
    profqwerty What's a Dremel?
    2 Jan 2006
    I'm a fan of CRT - I had a 21" CRT monitor that could do some rediculous resolution at very high refresh levels. Admittedly it was absolutely huge, but totally worth it! It produced real blacks and amazing contrast / brightness levels, action films always seemed to be better on it than on the LCD.
    Our TV is a flatscreen CRT, which is certainly better than the curved one as there's a lot less reflections, and the picture appears flat (makes a big difference on large screens). It does 100Hz so there's no flickering / whine. They also seem to be cheaper too.
  7. Krikkit
    21 Jan 2003
    QFT. I'm still using a 21" CRT, and although the picture is absolutely top-notch, it's a ballache to lose 2'6" of space on your desk... :(
  8. Smegwarrior
    Smegwarrior Fighting the war on smeg
    19 Nov 2007
    Want a picture 100" or bigger with the quality of CRT that doesn't stick out from the wall?
    CRT projectors!
    Nothing comes close to their quality or reliability, the only reason you see LCD/DLP being sold is because it is cheaper to produce and they know they will make money selling you bulbs every few hundred to 1000 hours or sell you a whole new one when something goes wrong with in in a year or 2 as they are not repairable or cost too much to repair, CRT projectors however are repairable and are worth repairing IF something goes wrong.
    The CRT's in CRT projectors last years and years and years and years, mine has been going for 14 years without any repairs or tube replacement, over 80,000 hours on the tubes, NO digital projector will last that long let alone the bulbs they use.
    CRT projection is still king! :rock:
  9. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    I'm trying to get a-hold of one of those beasties
  10. Firehed
    15 Feb 2004
    2 isn't necessarily true. Most plasmas have similar power requirements to CRTs. Not 100%, but you're not looking at a quarter of the power usage either. LCDs tend to be quite a bit better, but check the labels.
  11. modgodtanvir
    modgodtanvir Prepare - for Mortal Bumbat!
    28 May 2007
    On the rare occasions that I had to pick up my consoles and move them upstairs where we have an old CRT TV, I have actually been impressed by the picture quality of the CRT... it just seems better defined than on an LCD...
    Though I'd go for the LCD. Don't know why... just do it :p
  12. moonlight
    moonlight What's a Dremel?
    7 Jul 2008
    Can anybody explain me what are the advantages of flat TV over an ordinary TV?
  13. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    your joking right, can you even by not flat or widescreen tvs still
  14. BigD79
    BigD79 Gadding about...
    2 Nov 2007
    random.
    flat screens (correct me if i'm wrong, i'm sure you will) can display High Definition content (like Blue Ray discs, PS3/360 games, and HDTV) CRTs can't. They are flat, lighter and thinner than CRT TVs (ordinary TV's) so can live somewhere other than the corner of your room, like walls, fireplaces, ceilings, et cetera, et cetera. But they can use more energy, you could probably dry your washing on some of them, tho more eco friendly ones are coming out.
    Why do you ask?
    EDIT: sorry CRT's can display HD apparently.
  15. DougEdey
    5 Jul 2005
    Do you mean CRT Flat over CRT curved? Or LCD/Plasma compared to CRT?
  16. Krikkit
    21 Jan 2003
    Flat CRT vs. CRT: Less distortion to picture, often widescreen, generally newer.
    TFT vs. LCD: LCD is much thinner, lighter and nicer to look at, CRT is the last word in picture quality. Basically.
  17. badders
    badders Neuken in de Keuken
    4 Dec 2007
  18. Krikkit
    21 Jan 2003
    Merged for simplicity, I'd forgotten about that one. :D
  19. badders
    4 Dec 2007
    It was total Deja-vu, The thread titles were even the same!
  20. BigD79
    2 Nov 2007
    spam?
