I used a bit of this stuff in the latest revision and I'm pretty impressed. Its 10mmOD/7mmID any can be bent to fairly tight curves, but won't spring back and thus doesn't put any additional strain on the blocks. Very nice for the odd tight spot. EDIT: Or look at http://www.alphacool.de/perl/shop.pl?l=2&rm=get_art&menu_id=2&prod_id=160&art_kz=161&art_id=16126 They also do it in 8mm OD. Now what I'd really like is 12mmOD or greater for the pump section.....
Good find one question, on komplett they say its 10/8, alphacool says 10/7. Are they different products, or is the komplett one a confusion (i notice they only sell 10/8 tubing)?
Komplett confusion I recon. Will try and measure if I can. Komplett only stock the 10/7 as they're only doing 10mm parts (Watercool, Alphacool and Waterchill).
Has anyone found a source for this stuff in the US? It would go great for the project I am planning? Thanks, MatrixOps
