Other Flexible PCI x 1 extension.
Discussion in 'Hardware' started by Kronos, 15 Apr 2016.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    Only have one PCI E x 1 slot on my Sniper and that is blocked by the GTX 980 so I bought one of the blow and that does not work either end.
    Still do not have enough space to plug in the extension, though not by much. But at the sound card end Asus Xonar D2X I have no chance if I want it to fix into an IO slot.
    Is there anything I can use as surely I am not the first with this issue?
  2. Vault-Tec
    30 Aug 2015
    I had this issue a few years ago too. On the motherboard end the fibre glass plate was too tall to allow my triple slot cooler to go over it :(
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    I assume because of the lack of content in your post you were unable to solve this conundrum?
    Mine are too tall both ends by the way.
  4. Vault-Tec
    30 Aug 2015
    That sucks. I managed to rectify it by removing the cooler from my GPU and cutting down the posts that held the cooler up to make it dual slot. No idea what Palit were thinking tbh.
    Obs useless to you though hence why I didn't bother explaining it before.
  5. Kronos
    Kronos Multimodder
    6 Nov 2009
    Thanks I will look later about see what choices I have.
    Have just transferred my gaming PC from a Parvum to a Carbide case. What do you think the chances are of it booting first time?
  6. edzieba
    edzieba Virtual Realist
    14 Jan 2009
  7. Kronos
    Kronos Multimodder
    6 Nov 2009
  8. Kronos
    Kronos Multimodder
    6 Nov 2009
  9. edzieba
    14 Jan 2009
    That rotates the connector, but the wrong way: it points it towards the upper slot.
  10. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    Does the cable work in another PC? Worth trying to rule out if its faulty.
  11. Kronos
    Kronos Multimodder
    6 Nov 2009
    Well spotted. That would have been awkward if I had bought two of them, which was my plan until I saw delivery costs. Thanks.
    Worth working out if what is faulty?
  12. mrbungle
    20 Sep 2004
    I hear on-board sound is pretty good these days :p
  13. Kronos
    Kronos Multimodder
    6 Nov 2009
