Electronics Flip Flop
Discussion in 'Modding' started by RascalRusty, 20 Jul 2004.
  1. RascalRusty
    RascalRusty What's a Dremel?
    7 Jan 2003
    Hey all,
    Could some one post the self build circuit for a basic "flip flop" and the components I need??
    Thanks in advance
    Russ
    P.s - Bit cheeky, but if anyone can post the part numbers for the components from RS or Maplin, then that would be super helpful too, but if not I will have a root through myself.
    Thanks for your help all
    Russ
  2. Lynx
    Lynx What's a Dremel?
    24 Nov 2001
    Search for a JK or D type flip flop and they should come up. They come as a single package.
  3. RascalRusty
    7 Jan 2003
    is it a 4027 Dual J-K Flip-Flops with Set and Reset that i need, or 4174 Hex D Flip-Flop with Reset or a 4013 Dual D Flip-Flop with Set and Reset
    Thanks
    Russ
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
  5. kbn
    kbn What's a Dremel?
    17 Mar 2004
    nice photo, but what does it do? and whats a flip-flop?
  6. RascalRusty
    7 Jan 2003
    Thanks Cpemma, But I have no idea what the components are in the picture :idea:
  7. kill_me_quick
    kill_me_quick Big and Blue
    7 Jan 2004
    why dont you just order one off rs or somewhere?
  8. RascalRusty
    7 Jan 2003
    I was going to, but which one do I go for, or do they all do the same
  9. kill_me_quick
    7 Jan 2004
    I would say either the 4027 or 4013....personally ive only used the 4013 but i have the diagrams of both chips if you want them.
    4013:
  10. cpemma
    cpemma Ecky thump
    27 Nov 2001
    erm...it's a link...u can click on the picture...with a mouse :hehe:
    double pwn :rock:
