Modding floeresent paint
Discussion in 'Modding' started by P2D, 4 Apr 2004.
  1. P2D
    P2D 99.999% Pure Spam!
    26 Mar 2004
    Hey, Im gona paint the inside of my PC case with some floeresent paint and i wanna know what you all think about which color to use, i was thinking: *i,ll pick ONE and only ONE unless anyone has a cool idea*..orange, lime green, yellow, red...ive got a bl00 CCFL in and im gona get a gr33n one soon aswell..i was thinking about lime green but im not sure..whatcha all think
    P2D
  2. dom_
    dom_ --->
    4 Jan 2004
    if you are using UV paint then get a UV black light. I would stick to one colour though rather than mix blue and green. I allways think one colour looks that bit better
  3. Gooey_GUI
    Gooey_GUI Wanted: Red Shirts
    3 Dec 2002
    It'd be nice to know what color your case is. Do you have molding around the window? If so, have you considered transluscent molding? Some colors bleed through it and have a greater affect (good). When you say flourescent paint, I am supposing it is UV sensitive that you have in mind. If you plan on using other UV mods such as cabling, molex, fans, LEDS, sheathing or wiring then painting your entire case that same color can overwhelm the view. Have you considered your total picture?
    :idea:
  4. P2D
    26 Mar 2004
  5. nosmo
    nosmo What's a Dremel?
    5 Oct 2003
    Where would I be able to get some translucent molding to go around my soon to be created window.
  6. P2D
    26 Mar 2004
    heres a hole bunch: http://www.pcmodz.20m.com/images/ its a lame pre-mod that i got on a day trip to edinburgh and its a good case, no less than 7 80mm fan mounts *the one on the side panel has a 80-120 adapter on it for a large exhaust fan* but if anyone has any ideas on what i could do with it them please tell me :thumb:
    P2D
  7. P2D
    26 Mar 2004
    I just had a little think, and i realised i aint got a clue what i gotta do to the *steel* before i paitn it? do i need a primer or just sand it?? or be really lazy and just paint it?
    P2D
  8. Gooey_GUI
    3 Dec 2002
    Silver is good with translucent molding. If you want your MOBO and *stuff* to stand out then a plain flourescent paint won't accentuate it as well. If you have white anywhere on the board or you paint it carefully, then you can highlight the board under UV dramatically.
    Place a light of the UV color that you will be using in the case also. Having both choices on seperate inverters (each with its own switch) will give you the option of having pure UV, no UV, lights, lights & UV, and nothing.
    :thumb:
  9. Gooey_GUI
    3 Dec 2002
    Better ask that in the forum as a seperate question where people from over there are likely to see it. I found it difficult to obtain without buying an entire window kit. Also, there is Googol.
    :search:
