Flower Pot? sure, why not dude.
Discussion in 'Project Logs' started by The High Elf, 18 Aug 2004.
  1. The High Elf
    The High Elf What's a Dremel?
    18 Aug 2004
    Ok. no .bmp files :rolleyes:
    so we have:
    3 votes Cactus
    1 vote Pansies/Tulips
    1 vote 'solar plant'
    what the hell is a solar plant any way?
    Not much progress today. :waah: just trying to figure out how everything will fit and whether or not i need to line the inside of the pot with tin/tin foil/both.
    :idea:
    Yah...
    also i'm trying to salvage pieces of the casing from my old box. does anyone know how to take rivets apart?
    i think that's it
    Peace Out
  2. omicron
    omicron Baud.
    8 May 2004
    Your avatar wont work because you need a certain amount of posts to set an avatar for yourself. As for rivets, you'll need to drill them out.
    Good luck, this should be a fun project :)
  3. kill_me_quick
    kill_me_quick Big and Blue
    7 Jan 2004
    Avatar = 75
  4. -N4cR-Stigma2K
    -N4cR-Stigma2K Banned
    8 Jul 2004
    Avatar = 85
  5. The High Elf
    18 Aug 2004
    Will you guys stop fighting?!?!?!
    Can't you see you're tearing us appart?
    WHAT ABOUT US?!?!?!?!
  6. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    What about you?
  7. SFOD-D LoneWolf
    SFOD-D LoneWolf What's a Dremel?? :p
    10 Apr 2004
    What about me?
    :p
    Cheers,
    Mike
  8. bullfrog
    bullfrog What's a Dremel?
    18 Jun 2004
    what the hell is with all the spamming. Plz im trying to peacfully read this very interesting idea and now i have to listen to your blabbing on about bloody avatars. He is just trying to get some ideas, not spam. I say go for cactus. If you do your going to have to plan very well, as you dont want to water the plant and mobo. What you could do is find some of these small cactus plants and make a mini cactus garden. My mom has a bunch in a bowel.
  9. cogitoergosum
    cogitoergosum What's a Dremel?
    14 Jul 2004
    I also vote cactus.
    Also...rivets are a %&Q$&#()!(#*(@!^$#&!*@& to drill out. Make sure you have plenty of batteries (or a corded drill)!
  10. The High Elf
    18 Aug 2004
    Ok.
    Sorry guys, nothing good today. :waah: some BIOS crap and a SH!T-load of math. F%@#ing Circles. :wallbash:
    that was it.
    Over and Out
  11. Sunny-D
    Sunny-D What's a Dremel?
    11 Apr 2004
    whats so hard about drilling out rivets? i drilled about 7 of them out yesterday and it went easy. might have been the super power drill i was using, i dunno.
    great idea tho, this flower pot. i will be watching this.
    for the cactus, you could cut a circle of something, like acrylic/plexiglass maybe, and seal it with a silicone sealant to prevent water sneaking through.
    good luck and :rock:
  12. Hallq16
    Hallq16 What's a Dremel?
    30 Aug 2003
    I love the idea - pc in a flowerpot. Can't want to see, how this project evolves. Also it just gave me a similar modding idea... :idea:
  13. The High Elf
    18 Aug 2004
    My ATX power supply won't work. i've tried everything i could think of and have tested everything with my Voltometer but it's still a no-go...
    any thoughts?
    I Pitty the Fool
  14. Atarax
    Atarax What's a Dremel?
    13 Jul 2004
    Great Idea Can't Wait To See The End Result
  15. The High Elf
    18 Aug 2004
    The Delays Continue as the God-dammed power supply refuses to work.
    Appologies all around.
    Over and Out
  16. Mr. Red
    Mr. Red Minimodder
    1 Aug 2003
    Maybe I missed, but what is the PS doing? IF you simply jump the green wire to black, does it power up?
    As far as what plant to use, may I suggest an aloe vera plant? pic
    Or maybe... :idea: I am not sure how WC works, but could you use bamboo and use the water as a dual source: A resivor for the pc and food for the plant? I guess you could at least go for the illusion of that.
  17. The High Elf
    18 Aug 2004
    Life: Goodbye.
    OK.
    IT LIVES!!!!!! :eeek:
    the Bios is all set up and everything works.
    i did it. :clap: it took me several runs to Comp USA but i did it. :clap:
    i'll be away for the next 5 days :waah: but as soon as i return i'll start production on the flower pot. :rock: check in then.
    stay tuned.
  18. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    go with the catus that would be so cool, cause then if people try to take it they will get "prickled" and what you can do is have it like a plant growes in one pot that fits exaclty into the bigone and looks like just one pot, cause then you can remove it any time you want and not have to worry bout water getting in your system
  19. MrTroy
    MrTroy What's a Dremel?
    15 Dec 2003
    Go Cactus
    for several reasons, including less watering :p
    mod on....
  20. The High Elf
    18 Aug 2004
    HA HA HA!
    NOW THE SHOSTING BEGINS!!!!
    flower pot production (fpp) will start imediately
    i'll have pics up by tommorow. :clap:
    SAP
    !HA HA HA!
    !!!Y AHORA LA SHOSTING COMENSAR!!!
    ffp va a commensar imediatemente
    voy a tener pics por manana. :clap:
