Cooling flowmeter with max. flow 17l/m and pump AP1500 together
Discussion in 'Hardware' started by tauren, 19 Aug 2005.
  1. tauren
    tauren What's a Dremel?
    8 Aug 2005
    first thread on the forum...
    i have pump AP1500
    http://www.watercooling.de/catalog/product_info.php?cPath=1_4_88&products_id=471
    Technical facts:
    * Flow rate: 1500 l/h
    * Delivery height: 2,8 m
    * Input: 17 W
    * Connector: G 1/4"-connectors
    * Power supply: 12 V DC or 6-12 V adjustable (option)
    * Power cord with plug, circa 50 cm
    * Noise: circa 36 dBA (comparable with Eheim 1046)
    * Dimensions: 115 x 100 x 80 plus DC voltage converter
    * Weight: about 720 g
    and would like to know if it is possible to mount T-flow flowmeter T-Flow flowmeter
    http://www.mcubed-tech.com/eng/produkte.htm (specif. for jet 3.3)
    modell: plastic, white
    magnets: Ceramic Sr Fe O
    temperature range: -10°C to +65°C
    winding G1/4"
    connection: 3Pin-Molex (female)
    jet: 5mm
    impulse per liter: 275
    max.flow: 17 l/min
    as the pump has 1500l/h (25l/min)? ok 25l/min theoretically.
    that is 8l more that stays in max flow for flowmeter. if i connect these two things together would i be able to read the flows or this simply wont work becouse the pump is too strong?
  2. tauren
    8 Aug 2005
    anyone?
  3. roadkiller
    roadkiller What's a Dremel?
    6 Jun 2005
    You might want to check these out. They can be connected to the motherboard to a fan header and any program that can read the rpm of the fans can read the flowspeed (just a simple calculation). It can handle more flow so this might be safer to use, you'll know it'll work.
  4. slaw
    slaw At Argos buying "gold"
    13 Feb 2003
    i have never used one of these flow meters but i think that the blocks will reduce the flow some what especially if its a 10mm set up.
    looking this thread, the flow rates of the pumps drop dramatically when you add a block
    http://forums.bit-tech.net/showthread.php?t=73675
  5. tauren
    8 Aug 2005
    hmmm...i wanted to connect it to T-Balancer XL
  6. fivecheebs
    fivecheebs Dont panic!
    19 Feb 2003
    I think Risky has an AP1500 and a tBalencer. IIRC he has the flowmeter also, but im not sure if he uses it.
    What blocks do you have in your loop? Until i changed hardware i had an AP1500 with a NexXxos XP and i dont think there would be a problem adding it.
    Having said that the swissflow one is much less intrusive and would be the one i choose.
