Modding Fluoro Pens
Discussion in 'Modding' started by KelticFox, 3 Mar 2005.
  1. KelticFox
    KelticFox What's a Dremel?
    2 Mar 2005
    Question: Are fluoropens UV reactive??
    Would make a really cool idea to draw on MoBo and cards
  2. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    the fluorescent gel pens? Yeah, a lot of them are!
  3. Atomic
    Atomic Gerwaff
    6 May 2002
    Most highlighters are actually!
  4. nofear
    nofear What's a Dremel?
    2 Mar 2005
    would that work? drawing on the mobo?
  5. Da Dego
    17 Aug 2004
    With the fluorescent gel pens? Certainly. I don't know how well the ink would stay, but it would definitely work.
  6. KelticFox
    2 Mar 2005
    Remember you heard it from me first!!!
    I got dibbs!!! My idea. Not bad considering this will be my first mod
  7. Atomic
    Atomic Gerwaff
    6 May 2002
    Your not the first.
    Been done way back.
  8. mushky
    mushky gimme snails
    24 Mar 2003
  9. DarkInferno
    DarkInferno Minimodder
    28 Nov 2004
    normaly highlighters work fine
    soem are brighter then others... i think the yellow is the brightest glow..
    I used them to colour the edges of my cards, and its fairly effective but it does fade after a few months, but its not a chore to redo in my case :)
  10. Da Dego
    17 Aug 2004
    *ahem*
    you're kidding, of course. :) About the idea being yours, I mean (it does make a sweet looking mod).
    Good luck, and post pics!
  11. Infraggable Krunk
    Infraggable Krunk What's a Dremel?
    7 Mar 2004
    sadly, judging from his count post I dont think he was kidding :sigh:
    most uv pens will work, but uv blue is a hit or miss because most blue highliters and gel pens are not fluorescent
  12. nofear
    2 Mar 2005
    that is a pretty nice idea, i might have to try it sometime :p
  13. KelticFox
    2 Mar 2005
    Balls.
    And here I was hoping I had made a mark :duh:
    Oh well one one man can think of, another often has!
    Already started sketchs and designing, no big chore, but CAD is haaaard (specially when your used to programs like the Adobe series & Quark)
    Oh well no biggy, cheers though
  14. Da Dego
    17 Aug 2004
    Yeah, unfortunately if there's a way to glue it, hack it up, chop it, void the warranty, and now mark on it, it's been thought of. ;)
    That shouldn't mean not to do it, though...because there is as much originality in how you compile these ideas and produce a final product as there is in thinking up one of your own.
    My latin teacher waaaay back in high school used to say:
    "There is nothing original that has been written in literature since shortly after man first learned to write. What makes a writer great is their ability to say it again and have it still be interesting."
    :dremel: on, KelticFox.
  15. Sh00ter
    Sh00ter What's a Dremel?
    13 Oct 2002
    gel pens are better than others, u will still have to build it up in layers though, did mine quite a way back, they still look good :D i even started by painting the edges of me cards white (just enamel paint) so u get a better overall effect when u put the uv on it
  16. rick
    rick What's a Dremel?
    4 Mar 2005
    it kinda reminds me of tron
    i'm new to case modding so dont hate me for asking this but would a UV cathode still light up those pens if i had my blue ones on at the same time.
    also has anyone thort of using those invisible "securety markers" that show up under UV for doing stuff like that, or maybe for drawing on the case window for stuff thats only visible when you have the UV on
  17. Da Dego
    17 Aug 2004
    Rick,
    as long as your blue lights weren't too bright, it wouldn't interfere too much. There will be a slight diminishing of the effect, but not to the point where you can't see it anymore.
    Security tags? Hmmm...now that's one that at least I haven't heard of yet...wonder if anyone else has?
  18. rick
    4 Mar 2005
    i mite have to go buy some uv cathodes now *wonders over to ebay*
    do you think 4" ones would give out enough light when there was only an led case fan on for the other light?
  19. Sh00ter
    13 Oct 2002
    from my experience the jel pens light up a bit from the blue cathodes, but the blue will drown out a lot of the uv from a cathode, in my last case i had the cathodes switched so i could have blue or uv on
  20. Da Dego
    17 Aug 2004
    There are some mods over in the project logs that use both UV and blue, and it works alright. However, I'm not sure on the strength/size of each bulb.... Another option could be to use UV CCFLs and Blue LEDs, which could provide more point lighting and thus interfere less with the overall effect.
