FLYSURFER "PSU done!"
Discussion in 'Project Logs' started by speedybe, 14 Jul 2005.
  1. speedybe
    speedybe What's a Dremel?
    18 Apr 2004
    I just got it from my local hardware store the "brico". I think they sell it in every decent do it yourselve store.
    gtz
  2. speedybe
    18 Apr 2004
    nothing to special of an update, just a pair of expensive mirrors.
    the hdd's are 120gig each
    gtzzz
  3. H311R4153R
    H311R4153R What's a Dremel?
    28 Mar 2005
    Take a look at an autohardware store, they often have mesh which tuners use on their cars.
  4. theCrusifix
    theCrusifix What's a Dremel?
    27 Jul 2005
    the cheapest way to get mesh is called GUTTER GUARD...many people that i know use it for there tuner cars and its exactly the same and ALOT cheaper!!!!!!!! pick it up at a menards or home depot
  5. Sva4g3&*
    Sva4g3&* What's a Dremel?
    15 Jun 2004
    Them is some shiny HDDs, this looks real professional.
    -Rob
  6. speedybe
    18 Apr 2004
    Finally update time!!
    I thought I would never get to moddin again, been so busy with other stuff.
    Started the DVD-RW
    some pics :
    the piece
    ripped in pieces :D
    painted black and clear coated.
    Tomorow I will assemble the piece back together.
    What do you think, should I do a complete stealth mod or just paint the front in black.
    Give me your opinions!!!
  7. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Looks a good finish, I like the way you have kept the silver circle aswell :thumb:
  8. CraZy
    CraZy Cöstom úser tætel
    1 Feb 2005
    nice hdd's :naughty:
  9. speedybe
    18 Apr 2004
    I assembled the DVD-RW and decided to stealth it.
    The eject button will be relocated somewhere on the front. I just soldered the wires and made them long enough so I don't get in trouble later.
    I placed a soft mesh grill in front of the drive to cover it up a bit when the drive is opened. Off course this will be painted in blue.
    A picture...
    gtzzz
  10. poepeke
    poepeke What's a Dremel?
    18 Jul 2005
    well-done
    Hi dear,
    looks very nice, perfect circle,well-done
  11. speedybe
    18 Apr 2004
    Just put the wheels under the case, I like the look of it :D
    gtz
  12. speedybe
    18 Apr 2004
    part 1 of 2 of my order har arrived today.
    All black goodness.
    gtzzz
  13. speedybe
    18 Apr 2004
    just finished the blue mesh and mounted it on the dvd drive
  14. speedybe
    18 Apr 2004
    the first test assembly and a first glance on how the cable managment will be done.
    Keep in mind : test PSU, unsleaved cables, no soldering done, dummy cd drive and the cooling on cpu will be watercooling ff course!
    some money pics
    gtzzzzz
  15. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Looks great, but is that a Qtec PSU? :/
  16. speedybe
    18 Apr 2004
    read the post :eyebrow: It's a DUMMY part
  17. speedybe
    18 Apr 2004
    I painted the inside of the side panel in chrome, because it's visible from the window side.
    as usual, a photo says a 1000 words....
    what you think guys??
  18. MonkeySpank
    MonkeySpank Banned
    10 Aug 2005
    Looks really really nice especially the window panel
    Mod on :dremel:
  19. Strategy
    Strategy Banned
    19 Jul 2005
    What size bolt/screw did you use to attach the wheels? M6?
  20. kickarse
    kickarse What's a Dremel?
    6 Oct 2004
    Man that is a big case... very clean!
