Graphics FM Radio Tuner GeForce FX 5700 MSI
Discussion in 'Hardware' started by Esteves, 14 Apr 2006.
  1. Esteves
    Esteves What's a Dremel?
    14 Apr 2006
    Hey guys!
    Does anyone using this video card know how to configure the FM Radio
    Tuner??
    I´m using the MSI Radio program but I´m hearing nothing...
    Thanks!!!
  2. Austin
    Austin Minimodder
    16 Jul 2004
    :confused: I've never used the card but hopefully may be of some help. Did your card come with an FM aerial and 2 F-Type connectors on the backplate? I assume you've installed the software off the CD which is most likely pretty old, try MSI or nVidia's website. I think THIS is what you need (beyond the usual gfx drivers).
  3. Esteves
    14 Apr 2006
    my board don´t have these connectors, just a "cube" in the circuit called E3 that is supposed to receive the signals..
    Esteves
  4. Austin
    Austin Minimodder
    16 Jul 2004
    :( Those internal style aerials tend to be ineffective so that's most likely the source of your troubles. Not only is it encased within a metal box but there's simply too much 'noise' when things of this nature operate so close to your PC. I don't know what else you could do.
