Windows Folder Sync software (between networked PCs)
Discussion in 'Software' started by Guest-16, 12 Apr 2004.
  1. Guest-16
    Guest-16 Guest
    I want to sync my main pc work documents and my lappy work documents, anyone know any (free?) software that'll do this. They are connected thru a network.
  2. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    Try useing the brefcase thing in windows, these provide built in folder syncing functions.
  3. Guest-16
    Guest-16 Guest
    Found some free software in the end called Tech-Utilities Pro. Seems to work, if a little simple.
