folding on the GeForce GTX 680
Discussion in 'bit-tech Folding Team' started by planem997, 7 Apr 2012.
  1. planem997
    planem997 What's a Dremel?
    12 May 2009
    Has anyone folded on the new GTX 680, if so, what sort of PPD is it doing, temped to get one :p
    Thanks
    Adam
  2. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    I couldn't get mine to work.
    Maybe I need to use the new V7 client but I don't like it.
    It won't fold under the GPU3 client though.
    Very strange.
  3. Votick
    21 May 2009
    Just installed the v7 just for you.
    Doesn't work either :/
    GPU Load: 0%.
    Ah well :/
  4. StreetSam
    StreetSam Minimodder
    30 Aug 2005
  5. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
  6. Votick
    21 May 2009
    Did all that too.
    Still not working.
    Says the client is running but GPU is doing 0% usage :p
  7. planem997
    12 May 2009
    how odd, i might give it a month then, before i think about buying it, hopefully they will have a working client for it. anyways need aprils pay check to buy it anyways :)
  8. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    I read over on overclockers:
    You have to use the v7 Client and you need to add the command:
    "client-type:beta" to the gpu slot
    See: http://forums.overclockers.co.uk/showthread.php?t=18391807
    Does that help? I'm still on 480's so I can't test it...
  9. JohnSheridan
    JohnSheridan What's a Dremel?
    30 Dec 2010
    Yes that works and my 680 can fold however it is dog slow :sigh: so will wait until they get their app re-written to take advantage of the extra grunt the 680 has.
  10. lakedude
    lakedude What's a Dremel?
    2 May 2012
    How many PPD are you getting?
    I read somewhere that the 6xx cards have been tweaked to be better for gaming at the expense of GPGPU ability compared to the 5xx series cards.
