Motors For anyone who has ever read a Haynes manual...
Discussion in 'General' started by penski, 2 Dec 2004.
  1. penski
    penski BodMod
    29 Aug 2002
    For those who haven't used a Haynes Manual, these are the books aimed
    at those who want to fix their own vehicles and which keep qualified
    mechanics in paid employment putting things right afterwards. They are
    chock full of photos, diagrams and step-by-step instructions which are
    obvious if you are a fully qualified motor mechanic, but which are
    frighteningly sparse on detail for the average Joe in the street who
    wants to change a set of spark plugs on a 1981 VW Polo ....
    Hers are some of the more common phrases found throughout the manuals
    and their translations into real world english.
    Haynes: Rotate anticlockwise.
    Translation: Clamp with molegrips then beat repeatedly with hammer
    anticlockwise. You do know which way is anticlockwise, don't you?
    Haynes: Should remove easily.
    Translation: Will be corroded into place ... clamp with molegrips then
    beat repeatedly with a hammer.
    Haynes: Remove small retaining clip.
    Translation: Take off 15 years of stubborn crud, it's there somewhere.
    Haynes: This is a snug fit.
    Translation: You will skin your knuckles! ... Clamp with molegrips
    then beat repeatedly with hammer.
    Haynes: This is a tight fit.
    Translation: Not a hope in hell matey! ... Clamp with molegrips then
    Haynes: As described in Chapter 7...
    Translation: That'll teach you not to read through before you start,
    now you are looking at scarey photos of the inside of a gearbox.
    Haynes: Locate ...
    Translation: This photo of a hex nut is the only clue we're giving you.
    Haynes: Pry...
    Translation: Hammer a screwdriver into...
    Haynes: Undo...
    Translation: Go buy a tin of WD40 (catering size).
    Haynes: Ease ...
    Translation: Apply superhuman strength to ...
    Haynes: Retain tiny spring and/or ball bearing
    Translation: "Jeez what was that, it nearly had my eye out"!
    Haynes: Press and rotate to remove bulb...
    Translation: OK - that's the glass bit off, now fetch some good pliers
    to dig out the bayonet part and remaining glass shards.
    Haynes: Lightly...
    Translation: Start off lightly and build up till the veins on your
    forehead are throbbing then re-check the manual because what you are
    doing now cannot be considered "lightly".
    Haynes: Weekly checks...
    Translation: If it isn't broken don't fix it!
    Haynes: Routine maintenance...
    Translation: If it isn't broken... it's about to be!
    Haynes: One spanner rating (simple).
    Translation: Your Mum could do this... so how did you manage to botch it up?
    Haynes: Two spanner rating.
    Translation: Now you may think that you can do this because two is a
    low, tiny, ikkle number... but you also thought that the wiring
    diagram was a map of the Tokyo underground (in fact that would have
    been more use to you).
    Haynes: Three spanner rating (intermediate).
    Translation: Make sure you won't need your car for a couple of days
    and that your AA cover includes Home Start.
    Translation: But Novas are easy to maintain right... right? So you
    think three Nova spanners has got to be like a 'regular car' two
    spanner job.
    Haynes: Four spanner rating.
    Translation: You are seriously considering this aren't you, you pleb!
    Haynes: Five spanner rating (expert).
    Translation: OK - but don't expect us to ride it afterwards!!!
    Translation #2: Don't ever carry your loved ones in it again and don't
    mention it to your insurance company.
    Haynes: Compress...
    Translation: Squeeze with all your might, jump up and down on, swear
    at, throw at the garage wall, then search for it in the dark corner of
    the garage whilst muttering "bugger" repeatedly under your breath.
    Haynes: Inspect...
    Translation: Squint at really hard and pretend you know what you are
    looking at, then declare in a loud knowing voice to your wife "Yep, as
    I thought, it's going to need a new one"!
    Haynes: Carefully...
    Translation: You are about to cut yourself!
    Haynes: Retaining nut...
    Translation: Yes, that's it, that big spherical blob of rust.
    Haynes: Get an assistant...
    Translation: Prepare to humiliate yourself in front of someone you know.
    Haynes: Refitting is the reverse sequence to removal.
    Translation: But you swear in different places.
    Haynes: Locate securing bolt.
    Translation: Remember that worrying noise when you drove along the A38
    last summer? That's where you'll find the securing bolt.
    Haynes: Prise away plastic locating pegs...
    Translation: Snap off...
    Haynes: Remove drum retaining pin
    Translation: Break every screwdriver in your box.
    Haynes: Everyday toolkit
    Translation: Ensure you have an RAC Card & Mobile Phone
    Haynes: Apply moderate heat...
    Translation: Placing your mouth near it and huffing isn't moderate heat.
    Translation #2: Heat up until glowing red, if it still doesn't come
    undone use a hacksaw.
    Translation #3: Unless you have a blast furnace, don't bother. Clamp
    with molegrips then beat repeatedly with hammer.
    Haynes: Index
    Translation: List of all the things in the book bar the thing you want to do!
    Haynes: Remove oil filter using an oil filter chain wrench or length
    of bicycle chain.
    Translation: Stick a screwdriver through it and beat handle repeatedly
    with a hammer.
    Haynes: Grease well before refitting.
    Translation: Spend an hour searching for your tub of grease before
    chancing upon a bottle of washing-up liquid (dish soap). Wipe some
    congealed washing up liquid from the dispenser nozzle and use that
    since it's got a similar texture and will probably get you to Halfords
    to buy some Castrol grease.
    Haynes: See illustration for details
    Translation: None of the illustrations notes will match the pictured
    exploded, numbered parts. The unit illustrated is from a previous or
    variant model. The actual location of the unit is never given.
    Haynes: Top up fluids.
    Translation: Drink 2 cans of beer and call out a mobile mechanic to
    undo the damage.
    *n
  2. olv
    olv he's so bright
    23 Sep 2002
    that's brilliant :D some useful tips i'm sure i'll be needing in the future.
  3. BjD
    BjD What's a Dremel?
    10 Apr 2003
    hehehe, so true....:D
  4. Piratetaco
    Piratetaco is always right
    15 Apr 2004
    Mechanics jokes
    possible repost but
    Mechanics' humor
    HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate expensive parts not far from the object we are trying to hit.
    MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing seats and motorcycle jackets.
    ELECTRIC HAND DRILL: Normally used for spinning steel Pop rivets in their holes until you die of old age, but it also works great for drilling mounting holes in fenders just above the brake line that goes to the rear wheel.
    PLIERS: Used to round off bolt heads.
    HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
    VISE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
    OXYACETELENE TORCH: Used almost entirely for lighting various flammable objects in your garage on fire. Also handy for igniting the grease inside a brakedrum you're trying to get the bearing race out of.
    WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for the last 15 minutes.
    DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted part you were drying.
    WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar callouses in about the time it takes you to say, "Ouc...."
    HYDRAULIC FLOOR JACK: Used for lowering a motorcycle to the ground after you have installed your new front disk brake setup, trapping the jack handle firmly under the front fender.
    EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a motorcycle upward off a hydraulic jack.
    TWEEZRS: A tool for removing wood splinters.
    PHONE: Tool for calling your neighbor to see if he has another hydraulic floor jack.
    SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog-doo off your boot.
    E-Z OUT BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten times harder than any known drill bit.
    TIMING LIGHT: A stroboscopic instrument for illuminating grease buildup.
    TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile strength of ground straps and brake lines you may have forgotten to disconnect.
    CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool that inexplicably has an accurately machined screwdriver tip on the end without the handle.
    BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulfuric acid from a car battery to the inside of your toolbox after determining that your battery is dead as a doornail, just as you thought.
    AVIATION METAL SNIPS: See hacksaw.
    TROUBLE LIGHT: The mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under motorcycles at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
    PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; can also be used, as the name implies, to round off Phillips screw heads.
    AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts last tightened 60 years ago by someone in Springfield, and rounds them off.
    PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
    HOSE CUTTER: A tool used to cut hoses 1/2 inch too short.
    :hehe:
  5. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    LOL!!!
    ROFLApache!
  6. jetsetjimbo
    jetsetjimbo Up-up and away
    19 Feb 2003
    How amusing! The joy of Haynes assisted repairs :)
    The ultimate RTFM...
  7. k3nn
    k3nn What's a Dremel?
    2 Feb 2004
    :hehe: :hehe: :hehe: :hehe: :hehe: :hehe: :hehe: :hehe: :hehe:
    think that sums up the joy
  8. seagull
    seagull What's a Dremel?
    12 May 2004
    :D :D :D So many of the things just kinda happen :D :D :D I a bit of an expert on thread stripping and bodging :D :D Good old haynes :rock:
  9. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    So many of those are so perfectly true. Good stuff. :thumb:
  10. empyrean
    empyrean What's a Dremel?
    20 Sep 2003
    Oh wow, I'm tearing up because I've experienced those so many times over the last few months working on my fiancee's 10 year old mazda... retain tiny spring and/or ball bearing indeed...
  11. DeathAwaitsU
    DeathAwaitsU I'm Back :D
    27 Feb 2004
    OMG penski, that just had me in tears, literally thats the funniest thing i've read in ages :thumb: Cheers Mate.
    Death
  12. Golygus
    Golygus Minimodder
    9 Oct 2003
    LOL
    Have 5 of the damn manuals. surly enough, i have several sets of mole grips, and sod the chain for the oil filter :)
    Far too true, :)
