Windows Force feed driver into vista
Discussion in 'Tech Support' started by AJB2K3, 29 Oct 2009.
  1. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    I'm trying to install a proper driver from XP into vista (vista's one is crippled on purpose)
    Is there anything else I can do to "forcefeed" the driver install?
    Ive set the program to run a admin in XP mode but it keeps moaning that its not run as admin.
    Can anyone help?
  2. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    whats the driver for?
  3. Atomic
    Atomic Gerwaff
    6 May 2002
    XP Drivers aren't compatible with Vista.. you won't be able to force it to install, even if you did it the most you will manage is to make your system unstable.
    It's like trying to force a petrol car to run on diesel, it'll go in the tank but ain't gonna run the car!
    Vista and Win7 drivers are generally cross-compatible though.
  4. Krikkit
    21 Jan 2003
    +1.
  5. AJB2K3
    12 Dec 2005
    Its a printer driver as i said earlier I need the xp because the Vista one is crippled to make users by new printers.
    MS says you can install XP drivers
  6. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Pull the EXE open with 7-Zip or UniExtract and take a look at the INF files.
  7. capnPedro
    11 Apr 2007
    Paranoid much? Do you have a citation for this conspiracy?
  8. Krikkit
    21 Jan 2003
    Have you actually tried the Vista one? Or did you just buy hook line and sinker into some conspiracy theorists who just finished at Creative's forums? :p
