Forgot lock combo
Discussion in 'General' started by mattthegamer463, 17 Mar 2008.
  1. mattthegamer463
    26 Nov 2004
    After 5 long months of weather unsuited for biking, its starting to warm up. Today however, I realized that I do not any longer know the combination to my $40 bike lock. Its a Bike Guard 1500, and uses 4 rotating rings with 0-9 on each. Does anyone know of a way I can find my combination without spinning through every single possible one? I have tried all the numbers I remember, but nothing has worked and I've only managed to waste a hour of my life thus far.
    Its one of these. http://www.bonthronebikes.co.uk/402-431773
  2. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    dremmel? There are a lot of combinations it may be easier just to destroy the lock with a suitable tool and replace it.
  3. alastor
    alastor Minimodder
    6 Sep 2004
    Well if you did one combination a second it would only take 2 and half hours maximum, but perhaps you could try giving the manufacturer an email? If you can manage to prove that you do actually own the lock they might be able to tell you something useful.
  4. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    Try to pull really hard on the wire while you slowly turn one of the wheels at a time. Om many locks you can feel a very weak click on one of them. You will only be able to feel it on one at a time, so you have to try all 4 until you find one number, then follow the same method on the other 3 without moving the first one.
    This works best on cheap and new locks, but if you are lucky you could figure it out.
  5. Major
    Major Guest
    Any help?
    http://www.youtube.com/watch?v=zvfj4D8yUXw
    I had a problem like this, but basically I left it so long it got pretty jammed, and even though I had the right combination, it was bloody hard to get it out.
  6. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    +1, the way to picking quite a few locks.
  7. Smilodon
    25 Mar 2003
    That must be the cheapest bike lock ever! :hehe:
    Would probably be easier to just give the chain a yank until it brakes.
  8. mattthegamer463
    26 Nov 2004
    I tried the videos method, pulling on it doesn't make it move nearly at all, and theres a click after each turn of any of the rings but none make a distinctly different sound. After two minutes of turning I can't find a consistency. Its a quality heavy duty lock, you can't really buy much better. The cables the width of my finger, its probably the biggest lock I've ever seen.
  9. Firehed
    15 Feb 2004
    The whole idea behind combo locks is to make it impossible to have a method that bypasses knowing the combination. You can bet that if the info existed, the first people to get it would be thieves.
    I think you're in for a few wasted hours of random guesswork.
  10. Loz
    Loz Blah Blah
    16 Apr 2002
    Stick something like the Lord of the Rings on and relax ;)
    You'll save yourself the $40 for a replacement that way too.
  11. FIBRE+
    FIBRE+ Minimodder
    27 Feb 2005
    2nd that, it's the best technique. Done it in the past at work when bored, takes a few minutes if that, unless it's a really well made lock which combi's generally are not.
    Or you good spend a few $ on some cheap bolt cutters :p
  12. cpemma
    cpemma Ecky thump
    27 Nov 2001
    From the responses, you lose either way.
    • If the lock can be easily picked, you've wasted $40;
    • If it can't, you'll end up destroying a $40 lock.
    Life is a series of learning experiences. :sigh:
    How about a hypnosis session to recall the combination? :idea:
  13. Brett89
    Brett89 Minimodder
    15 Dec 2005
    I have a similar style lock, if you can move the rings slightly to see the dimple created by the plastic that slips over the metal nipple signifying that is the number. I had one with numbers completely worn off from my tires, and thats how i' figured out the combo after a long while.
  14. Smilodon
    25 Mar 2003
    It would probably cost you more time to find a quick method of unlocking it, than it will take to do it the hard way... ;)
  15. outlawaol
    outlawaol Geeked since 1982
    18 Jul 2007
    I had done the same thing on a 4 combo spinning lock. But I developed a method to crack the combination. I had a small ammount of play between the rod with the teeth and the spinning rings that are the combination. I basicly pulled at the rod end and spun the numbers till I got more play. Basicly did this with all four and did eventually get it unlocked, took like 30-40 mins if I recall, but if you have sensitive fingers and can feel the play between then you should be able to get it (assuming you have at least a half decent ammount of play to begin with)
  16. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
    Was about to say that. If you practice then you can get through a number of different locks with that method and use it as a method for picking padlocks even. Certainly entertained me through a mischievous childhood.
  17. thestig198
    thestig198 Artificially Intelligent
    24 Jan 2004
    If it takes 1 second to try each number then in under 3 hours you could have tried them all. It would be possible to do it in even less time than that if you clamp one side of the combination then turn the dials while pulling on the other side.
  18. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    If it's a good lock, the only way to get it open will be to spin through every possible combination. Fortunately, as tom_goodyear says, even at the relatively slow rate of one number per second, it'll take a bit under three hours to try all possible combinations. It's mindless enough work that you can put on a good movie while you work.
    But don't forget to try 3141 first. ;)
  19. Squadexodus
    Squadexodus I got my cookie. What about you?
    5 Jan 2008
    Blow torch. Cough cough
  20. dragontail
    dragontail 5bet Bluffer
    9 Jun 2005
    Just grind it out matey. It's unlikely that it'll take the full 3 hours either, as that assumes the number is 9999. If your number is like 2459 or something, it'll take you roughly 40 minutes. Of course, if you can't be assed, it's probably better to go for the boltcutter.
