formatted/ not formatted
Discussion in 'Hardware' started by Ryu_ookami, 22 Dec 2004.
  1. Ryu_ookami
    Ryu_ookami I write therefore I suffer.
    11 Mar 2004
    I've been changing some stuff with my pc. Before i started one of my drives had just under 31 gb od data on it. Now when it started its showing that drive as healthy but unformatted. How do i get the data back if at all.
    i'm using windows xp sp2
  2. olv
    olv he's so bright
    23 Sep 2002
    have u tried slaving it in another machine? have you reinstalled/changed OS?
    if winxp is seeing it as unformatted then you might be rather screwed. you could download Partition Magic or similar to see what it makes of it.
  3. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Its likely that all your data is lost. :( You could try looking in Dos to see if it can read them :hehe: but honestly, theres a good chance that all the data is gone.
  4. theflinger
    theflinger New Member
    21 Mar 2004
    would it be beyond a recovery tool?
  5. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    There's a chance you can get everything back. It sounds like a partition inadvertently got deleted. I recommend Active@ Parition Recovery off of the Ultimate Boot CD. That one personally saved my butt once, since it was a 200GB partition with all of my music and TV on it.
