News Former Valve staffers unveil CastAR
Discussion in 'Article Discussion' started by Gareth Halfacree, 20 May 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    Wouldn't this mean a further halving of frame rates?
  3. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    From my understanding liquid-crystal shutter glasses only block your eye from seeing the image intended for the other eye, the projector is what displays the image so frame rate would depend on the projector.
    What i want to know is when we will be able to plug our selves into a game, after all our senses are nothing more than electrical impulse sent to our brains :hehe:
  4. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
    That's slightly misleading in the way it's phrased. I've changed it to simply say "the system allows..."
    The point is that what users are seeing is their own projection not a 'universal' projection like in virtual reality systems that use TV screens or rear projection displays. Here several people can be in one reflective box/environment/holodeck and can be having their own unique experience of the virtual environment. There's the potential for some interference if multiple users are looking at the same spot but the combination of the retro-reflection and the timing on the shutter glasses should keep this to a minimum.
  5. ashchap
    ashchap Minimodder
    28 Feb 2005
    I suspect that is the main reason for the retro-reflective surface and the head mounted projectors - the light from the projectors will be reflected back only in the direction it came from i.e. back to the user's eyes and not to anyone else's. If it is effective enough then there should be no limit to the number of simultaneous users.
    This also means a much less powerful projector is required as very little light is wasted.
    http://en.wikipedia.org/wiki/Retroreflector
  6. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    AH! I see now, Thanks Meanmotion and ashchap.
  7. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    For anyone thinking "this looks familiar", this is essentially 1998's X'tal Vision HMD, without the hilariously large headset.
  8. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    OK, next question... How do they deal with convergence of the projectors? Do yyou need to be a very specific distance from the screen?
  9. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    ...not to mention focus!
  10. Griffter
    Griffter What's a Dremel?
    1 Jun 2012
    Oculus Rift :)
    then Logitech ChillStream edition can make an oculus rift with streams of air 2.0
  11. Griffter
    1 Jun 2012
    PS: i caught the matrix snippet :)
  12. LordPyrinc
    LordPyrinc Legomaniac
    7 Mar 2008
    Sounds a little too complicated for the task they are trying to achieve. I'm thinking more along the lines of 3D glasses (ones with their own screens, not shutters) mounted with motion detection hardware. Then add a couple of cameras (also mounted on the glasses) to detect the LED object being held and moved by hand (i.e. the LED chopstick). Either way you're still going to have to plug the glasses into something for the game/video feed, but at least you eliminate the whole weird reflecto screeno gizmo. It's not like you would be walking around while wearing the device anyways.
    Basically something like this but with motion sensing and cameras.
    http://www.sony.co.uk/product/personal-3d-viewer/hmz-t2
  13. notmeagain
    notmeagain Minimodder
    29 Jan 2009
    Why bother with augmented reality right now?
    Some of the indie developments coming from the oculus rift project are staggering to behold, in my eyes AR will be quickly superceded by Augmented VR, where with the use of external sensors your body is mapped in realtime with the avatar in the game/simulation.
    AR definitely has it's place, be that as a HUD in a car, glasses etc, but for an immersive gaming experience AVR is definitely the way forward.
    Yes, it's reclusive and limits "social" interaction... but come on! being trapped in Skyrim for 18 hours in full VR? you can't ask for more. (work safe material that is)
