Development Forum blank line addition (line break)
Discussion in 'Software' started by puzzler_uk, 19 Jul 2004.
  1. puzzler_uk
    puzzler_uk What's a Dremel?
    7 Sep 2003
    Ok i wrote my entire forum for my site. benshole.tk but something i failed to think about was how to get the ASP to write a <br> from an actual line space in the text area. For example on this professional decent message board, when i press return
    i actually get the line spaces. But on mine, it doesnt. Because it saves it as one big line into the access database for the forum. Does anyone know how to get it to see a line and replace with <br> I have a find and replace script already for inserting smilies. So if its a case of looking for a particular ascii code then it wont be too hard. Thanks alot.
    Ben
    Bens Hole
  2. mookie
    mookie very nawty<br><img src="http://mookie.org/i/avatar
    30 Jun 2002
    Did a little searching ("nl2br() in asp") and found this:
    Code:
    replace(TheString, vbCrLf, "<br>")
  3. puzzler_uk
    7 Sep 2003
    Thanks man, that was exactly 100% what i needed. Great stuff.
