Helloo.... Ive been to several other forums but i cant really figure out this one. soooo I had some questions: How do you change your avatar? How do you change the thing under your username? (dont know what its called) Is there a way that when you post, you are automatically subsribed to that thread? THANX!!!!
1) you need 75 posts 2) you need over 650 (i think) posts 3) I dunno, check user CP. 4) moving thread to the 'feedback' forum 5) spamming to get avatar will be frowned upon. *n
1) You need 75 posts before you can have an avatar [Then just change it in the User CP] 2) You need 750 posts before you can have a custom title [Or less if a mod likes you ] [Also changed in User CP] 3) AFAIK, once you post in a thread you are automatically subscribed to it. [EDIT: Damn you, penski]
ok, fair enough, on xoxideforums you need 30 store points (accumalated from posting) to get/ change your avatar.. wow 650 posts.. lol maybe in a few years.. but thanks for the help! oohhh... once you have 60 posts, can you change your avatar as much as you want?
2) You need 750 posts before you can have a custom title [Or less if a mod likes you ] [Also changed in User CP] Spamming gets you a nice title which 56k forever has, also emma had a nice formaly emz title. Welcome to the forum(s)??, and happy modding. EDIT: beware of penski, he bites
