Electronics Forums | PICAXE Forum | Has anyone used the MAX7300 i/o expander
Discussion in 'Modding' started by agray1, 12 Jan 2005.
  1. agray1
    agray1 What's a Dremel?
    12 Jan 2005
  2. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    yes with mid range PICs only thou, its a narly chip, quite cunning how you set the ID on the thing for the I2C bus.
    It does exactly what it says on the tin, but its not that fast thou.
    Its good because i used it for long range, well not that long, but longish range extension of some LEDs, i had it controlling 6 iirc with 16 brightness levels (done with resistor ladder).
    any questions?
  3. agray1
    12 Jan 2005
    Thanks
    Thanks for reply. Just thought i'd get someones opinion as they could be quite useful for expansion of existing projects.
    How slow are they?
  4. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    much slower than just using some latches, which are cheap + redilly available.
    but the advantage is it only needs two pins, and I2C is easy to implement.
