Electronics Found 2 displays...
Discussion in 'Modding' started by Jaguar_5, 12 Apr 2002.
  1. Jaguar_5
    Jaguar_5 What's a Dremel?
    10 Apr 2002
    Heres the deal, i found 2 displays laying around, basically im wondering WHAT they are and if theres a way to salvage em and put them to good use!
  2. viridius
    viridius What's a Dremel?
    7 Apr 2002
    It looks like you've got two eight-digit alphanumeric VFDs. You'll need an inverter and a driver IC to make any good use of them. The wiring is probably more than a little tricky. I'd just buy one premade.
  3. Jaguar_5
    10 Apr 2002
    I can deal with complicated wiring
    Any clue how much an inverter and IC would cost me?
  4. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    perhaps we can find out what this is and how to wire it too
  5. crystalfontz
    crystalfontz What's a Dremel?
    9 Nov 2001
    I think they may be 5x7 LED matrix displays. Actually quite expesnive little units. If my guess is right, it would look like this powered up:
    To see if that is what it is, take a 5v through a 2K resistor (2.5mA) and try it on random pairs of pins. If you can get some pixels to light up then that is what you have.
    +5v
    (wire)
    (2K ohm resistor)
    random pin 1 on display
    random pin 2 on display
    (wire)
    ground
  6. Jaguar_5
    10 Apr 2002
    Is that directed to me or bee?
  7. crystalfontz
    9 Nov 2001
