Windows Found a hint for a possible Vista SP2 on MS website
Discussion in 'Software' started by GoodBytes, 24 Aug 2008.
  1. GoodBytes
    20 Jan 2007
    Hello,
    So I was about to download a fix for eSATA HDD's for Vista 64-bit SP1 (also available for 32-bit, if you ask). The Hot fix is in beta. But when I went to the website I see this on the update to request the beta version:
    Does that mean that they plan it to be release on SP2 of Vista?
    Is Vista SP2 be out shortly after/before Windows 7?
    Is Windows 7 Vista SP2, as the Windows Server 2008 will just have an update and nothing more?
    Linky: http://support.microsoft.com/kb/950186/en-us (click on "View and request hotfix downloads") at the top left corner of the page)
    What do you think?
  2. capnPedro
    11 Apr 2007
    Typo?
    Yeah, I'm a cynic I guess.
    But where you really expecting support to end with SP1?
  3. Guest-16
    Guest-16 Guest
    Fix for eSATA hard drives? What chipset does it use? I've had no end of trouble with JMicron ones on 32-bit and 64-bit Vista with and without SP1.
  4. GoodBytes
    20 Jan 2007
    Well I don't have an eSata HDD YET, I order one... so I'll see if it works. For a friend of mine he has issues. He did not come across testing this patch mentioned yet.
    For my case, I don't know the chip my motherboard uses. (see signature for my compy specs)
    But when I tested with a normal SATA HDD, it fails to detect it when it's plug-in/out. I have to shut down the computer and perform the switch.
  5. Guest-16
    Guest-16 Guest
    Silicon Image Sil3132 - is it set to ACHI in the BIOS (is there an option?)
  6. quack
    quack New Member
    6 Mar 2002
    Nothing new. A lot of updates for XP were marked as SP3 over a year before the first beta even appeared. Basically anything that gets released after a service pack is automatically marked as being for the next one (even if one never appears).
  7. seanblee
    seanblee New Member
    17 Jun 2001
    Quack's spot on - if you look closely, all current XP updates are labelled 'sp4', and it doesn't look like MS are even planning on releasing one of those.
  8. Akava
    Akava Lurking...
    28 Jul 2007
    It probably just a way of easily keeping track of updates that would be stuck in the next service pack should it come to pass.
