Hey people, I recently purchest Foxconn Blackops motherboard and cant find any clear stable overclocking settings for it. Can anyone share their settings for blackops/q6600 combo? My rig is: Intel Core 2 Quad Q6600 2.40 GHZ G0 Corsair H50(watercooling) Foxconn blackops x48 G.Skill Ripjaw 4GB DDR3 1600MHz Sapphire VAPOR-X HD 4890 1 GB Microsoft Windows Vista Home Premium SP1 32-BIT OCZ 600W Stealth XStream - Low Noise
I may not be able to help you, but I'm hoping you could help me. How good is the cooling on the H50 with your Q6600 on stock? What are your temps? I've been having a dilemma of replacing my TRUE with the Corsair H50 for a week now and cant seem to find and good comparison between the TRUE vs H50 on a Q6600.
Idle around 35c, running prime95 atm, doesnt go higher than 54c, will leave for the night for oc testing. P.S is there down side of using "Instant OC", profiles that comes with Motherboard?
If I were you I'd just experiment, most boards are pertty much guaranteed to hit 3GHz without playing with the stock voltage, but 3.4GHz is easily doable on air with a good board
