News Foxconn goes Enthusiast Crazy
Discussion in 'Article Discussion' started by CardJoe, 5 Mar 2008.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. Arkanrais
    Arkanrais What's a Dremel?
    14 Jul 2007
    awww. no pictures of the 8 screen flight sim.
  3. hawky84
    hawky84 SilentModder
    15 Nov 2007
    loving the idea of using as little chemicals as possible in the manufacturing process, good to see someone is putting the green name as more than a gimic
  4. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    Ok this is all ridicalous!
    1) If the case is so huuuuuuge i want to see the whole damn thing, not a part of it :(
    2) Then you see a cool lookin mobo called dreadnought with a waterblock on it, but it is cooledr by a thin 80mm fan almost blocking the first PCI-E slot. (i guess a normal size 80mm fan would block the first pci-e slot completly)
    2a) The fan would probably be useless anyway, cause the inlet is sitting 2mm from a graphicscard backside, blocking the airflow.
    3) First you see a picture with GREEN and leaves, saving power bla blabla. And below that, a huge powerconsuming overclocker with huuuge hydrogen coolblock beating the crap out of the dreadnought. And note the videocard in pci-e slot 1 next to the chipsetfan. Its at a 10 degree angel moved away from the cooler otherwise it would block the airflow (see note 2a above)
  5. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    those acronyms are mad.....
  6. naokaji
    naokaji whatever
    8 Dec 2006
    wait till you see the Asus Mainboard called Pinot Noir..... (seen it on xs, seriously, its not even funny anymore what marketing comes up with these days).
  7. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    is it just me or Dreadnaught is a 790 chipset, NOT 750?
  8. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    I read that as well. hmmmmmm....... :eyebrow:
  9. Guest-16
    Guest-16 Guest
    Corrected - I've got numbers coming out my ears today :( Everyone has a "7" everything product this year.
    It's actually a 790i Ultra SLI which is different to the standard 790i SLI as well.
  10. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    So does the ultra-ATX fit e-ATX boards? If not someone really needs a kick in the jewels.
  11. Guest-16
    Guest-16 Guest
    No ultra ATX is a concept made by Foxconn. Having said that, I saw a Thermaltake case today that could fit one (10 PCI slots).
  12. Cthippo
    7 Aug 2005
    It's more than just the slots though. I've got any number of cases that can for all the PCI slots, but aren't long enough. 12x13 makes for a very deep case.
  13. salesman
    salesman What's a Dremel?
    29 Apr 2007
    I'd like to see how the MB in the bottom right picture fits into any case.
  14. Bluephoenix
    3 Dec 2006
    CMS830 family and the thermaltake armor family will take any motherboard I've encountered, even server boards.
  15. Guest-16
    Guest-16 Guest
    It doesn't, it's not meant to - it's an ultra ATX prototype that shows of Foxconn's engineering skill.
  16. zoom314
    zoom314 Minimodder
    10 Jun 2003
    As Yes the Dreadnought(HMS Dreadnought was the first all big gun battleship of Her type and She made all older designs instantly obsolete), SLI and the 790i chipset, Looks interesting, Now somebody needs one named after HMS Agincourt, When It laid out a full broadside, It looked like the ship was in fact blowing up(This was from what I've read as I'm not that old) as the Agincourt had 14 12" guns in 7 Twin(barreled) Turrets and all 7 turrets were on the center line of the ship. http://en.wikipedia.org/wiki/HMS_Agincourt_(1913)
  17. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    That 8 screen setup is sweet
    Need pics of the whole case
  18. Guest-16
    Guest-16 Guest
    Aren't I good to you lot? :) Bearing in mind that's the ULTRA ATX board next to it - bigger than standard ATX.
  19. Guest-23315
    Guest-23315 Guest
    One hell of a fugly case. We need to be moving towards small systems, not huge ones.
  20. Bluephoenix
    3 Dec 2006
    +1 (as long as they don't become as unbuildable and unmoddable as laptops are today)
Tags: Add Tags
