FOZZBOX>>>>>>>>> 9/10 RADIATORS ARRIVED
Discussion in 'Project Logs' started by Fozzy, 16 Aug 2005.
  1. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    Newegg for like 150 shipped. This thing is amazing
  2. Fozzy
    25 Jan 2005
    UPDATE>>>>>>8/18
    Well i finally got to some modding last night which was a blast. Not too difficult. Just drilling out some rivets and putting in a Black Ice Pro
    Here's a picture of the bottom support i had to remove for my pump and radiator.
    the other bracket i had to remove.
    My tool of choice : )
    Action shot of me drilling out the rivets
    first cage removed
    Second cage removed
    Before and after shot
    It really opened up alot of space
    Full on shot
    The mammoth fan installed by antec. I just saw it when i took it out. It's like twice as big as the average fan. : ) Definately gonna be my radiator fan.
    Silicon dampners from my unused drivecage.
    Soon to be used as grommets. But for what : P
    Where the first radiator is going. And it was a biotch to get in...
    Here she is
    Had to drill out the wholes for the bolts to fit
    Frontal
    backal
    sideal
    well that's about it for now. I'll probably get started on the VGA retention clip today.
  3. r00t69
    r00t69 What's a Dremel?
    2 Apr 2005
    Great start Fozzy. This case was on my shortlist so I'm interested to see how it turns out.
    Subscribed :thumb:
  4. Fozzy
    25 Jan 2005
    TY This case just makes it to easy. I almost feel like i'm cheating. They only realy hangup so far is where i'm going to run the tubeing. I'm gonna try to route it along the right side up to the top but if not i'm gonna have to render my floppy unuseable : P. I'd kinda like to keep it
  5. phuzz
    phuzz This is a title
    28 May 2004
    nice case, I'd not seen one before, quick Q tho: How would the PSU fitting work with a power supply with a bottom mounted 120mm fan?
  6. huren
    huren What's a Dremel?
    14 Aug 2004
    fans only there too pull air through the psu. as long as it spins ( creats air ) theres no problem.
    correct me if im wrong =]
  7. phuzz
    28 May 2004
    What I meant was, most psu's have fans front and/or back, but some have a big fan on the bottom, and from the pics in this case it looks like that opening would be covered, I'm sure it's easily done, it's just a bit hard to make out from the photos...
  8. Fozzy
    25 Jan 2005
    The case was designed so the PSU could be mounted Right-side-up and upside down if that makes sense. It also is lifted off of the floor of the case. I took some pics for ya.
    Here they have a hole for the bottom fan.
    here you can see they left the bracket open for airflow
    and here you can how the fan pushes air directly into the fan.
  9. Fozzy
    25 Jan 2005
    That's true but it would also be blocking the flow of air which would in turn slow down the airflo. It doesnt really matter though because this case already took that into consideration
  10. hitman012
    hitman012 Minimodder
    6 May 2005
    Excellent work. I love the P180 and was hoping that someone would watercool one soon :D
    Subscribed :thumb:
  11. Fozzy
    25 Jan 2005
    Haha thx. I hope to be the first. I doubt i am tho. SOmeones prolly already 1-upin me right now
  12. Jipa
    5 Feb 2004
    That case still looks damn good. Finally case with SIMPLE frontpanel... Internals atleast look quite well-designed too. For sure I'd like to won case like that from somewhere :D
  13. Fozzy
    25 Jan 2005
    One of my fav parts is the front. I've thought of modding it but i like the idea of "simple on the outside, modheaven on the inside"
  14. Fozzy
    25 Jan 2005
    UPDATE 8/19
    OK so my birthday is on the 25th and since my mom never knows what i want she let me make an order to voyuermods.com
    here it is
    1 PolarFLO TT Series Universal Chipset Acrylic water block $39.99
    1 Swiftech MCRES-525™ Reservoir $16.95
    20 PrimoFlex UV Blue Tubing - 1/2 inch $19.80
    2 Acoustic Absorption Mat $25.00
    10 Rubber grommets 1/8 groove 4 pack $9.90
    10 C-Strip Fan/Edge Molding $7.50
    2 Dual 12 inch Cold Cathode Kit - UV $7.98
    2 Dual 12 inch Cold Cathode Kit - Blue $17.90
    Subtotal: $145.02
    Tax: $0.00
    Shipping: $21.35
    Total: $166.37
    Thx mom!!!
    Should be here in 3-5 days
  15. Fozzy
    25 Jan 2005
    UPDATE>>>>> 8/20
    Got my Zalman VGA HS. In the mail a while back and took pictures but forgot to load them. Here they are.
    Look how shiny thebase is : )
    It's very well balanced and the fins are very thin which makes this cooler not so heavy.
    OOOOOOO look at the goodness
    Installed. This thing was not the easiest thing in the world to install. But i think i did it backwards. Ohh well. It has one of the best brackets i've every seen. 2 thumbs up.
    A little bit of advertizeing
    ohhh preeeeetty
    Ramsinks i havnt put on yet. Wanna use better paste.
  16. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    I'm not sure if this has been mentioned but the fans on the radiator should be in a push-pull configuration for bette results. The fan inside the case should suck air through and the one outside should push air :thumb:
  17. ou7blaze
    ou7blaze sensational.
    5 May 2003
    Lookin nice so far.
    Temps should be alot better with that new zalman cooler but I don't think the ram sinks will give more than a few mhz in terms of overclock timings.
  18. r4tch3t
    r4tch3t hmmmm....
    17 Aug 2005
    Great mod, makes me wish i had more time an money, or ur mom so she could get me teh stuff. Keep it up Fozzy.
  19. Fozzy
    25 Jan 2005
    They are.....
  20. Fozzy
    25 Jan 2005
    That's why i havnt stuck them on yet. I might resell them on ebay seeing they go for like 18 bucks.
