FOZZBOX>>>>>>>>> 9/10 RADIATORS ARRIVED
Discussion in 'Project Logs' started by Fozzy, 16 Aug 2005.
  1. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    Yup. I'm fixing the problem right now. Should have everything up by the end of today
  2. Bluefan
    Bluefan test 123
    25 Feb 2005
    had the same problem, in 6 days I used 1500 MB of bandwith. Now I use imageshack, and it goes pretty well.
  3. Fozzy
    25 Jan 2005
    I really hate that you can only upload 1 image at a time unless you pay for more credits. I've decided i'll just make 3 or 4 photobucket accounts and spread my log pics across those
  4. Arkuden
    Arkuden mow?
    9 Jul 2004
    ok so i have a questions seeing as i have folded under the pressue lol. Does it appear that there will be enough room to mount a 120.1 BIP to the top 120 mounted fan? Ive got one of those high performance panflos thats about as thick as a BIP and i dont know if there will be any clearance seeing as the multifunction panel is pretty close to the top of the case...
  5. Fozzy
    25 Jan 2005
    I'm not sure yet. I think there is but i'll check again. If not then the fan is going on the top of the case and i'll have to mod the scoop
  6. Fozzy
    25 Jan 2005
    UPDATE 8/26 CABLE SLEEVING
    Thos update may not show it from the pictures but alot of work was done. Sleeving cables SUCKS!!! Lemme just get that out of my system. I must admit the overall effect if gorgeus though. The pics dont really show the quality either.
    $30 bucks of sleeving goodness.....and it was the wrong size so I had to take it back. I was too frustrated from 30min of extra driving to take more pictures of the sleeving. So there
    A better picture of how the case looks right now since my last few were fuzzy.
    A picture of the back motherboard tray. Notice the molding on the right and the foam on the upper left.
    Bottom rack with more foam around the "PSU Float" and inside of it. (just to darken it up a bit because of the ammount of cables that will be down there. It'll make it look less messy.
    My rig as it stands now
    $50 well spent on a SLEEVED 480w PSU. Cant remember the brand but it isnt terrible. Pluss it's quiet.
    mmmm look at the cables
    I was takeing a molex of this Antec fan that came with my case and noticed the hinge. Cool idea. Too bad i need the smaller fan molexes
    My test setup as i was saudering everything (did i spell that right?)
    That would be my zalman 4 port fan controller with 2 5-9volt switches
    Itty-bitty fan molex
    Heatshrink on top of the sauder
    First ever sleeve job. Turned out nice
    Double-take
    1 fan down....5 to go.
    Everything i sleeved before i ran out of sleeving. I still have 3 more fans, 1 more extension wire, 1 audio cable, 8 ccfl's and their power leads, and the pump that hasnt gotten hear yet.
    All of the audio/usb/power headers are in yellow.
    The 3 fans i completed
    Testing out lighting for my case so i can decide how to sleeve my cathodes.
    another shot
    And the chipset block i ordered.....or at least the AMD version.....uggggh.
  7. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    Nice sleeving, looking good so far :)
  8. Fozzy
    25 Jan 2005
    Thank you. It has to be one of the worst jobs ever.....
  9. Fozzy
    25 Jan 2005
    UPDATE 8/27 MIDNIGHT MODDING
    Last night we had a loss. I was drilling out the holes in my BIP and the effin drill slipped :wallbash: . So now there will be 3 radiators instead of 4. This will be fine though because i was worrying about the pump and whether or not it could pust the extra rad.
    ANyways. I did manage to get some modding done last night to my neighbors expense (listening to the air compressor) so here it is.
    This wasnt looking to good
    And this needed to be removed for the hoses on the second Radiator.
    Some of this will save me from massive cleanup later which is very hard to do with this case.
    You get the idea
    Everything had to be covered because the paxmate is not removeable.
    First cut
    Came back with my 4inch and grinded her smoothe.
    A little bit of this, a little bit of that
    Girl shake that thang, keep crackin that back....haha i love snoop dogg. But really it looks alot better
    see where i'm going with this? prolly not. I have to remove part of this fan things side for cable routing and a uv cathode
    This time the entire thing gets covered
    This actually took twice as long to do as the cutting itself
    and the other side will get the same treatment.
    My modded cutting disk
    This stupid gard was keeping me from finishing the cut so it had to say byebye. I'll put it back on later.
    Rough cut
    Smoothe cut
    Looks pretty with the molding
    A few more shots
    now onto the other side. Rough cut
    Smoothe cut
    FInished
    Cant tell much of a difference but it will make a huge one when i start wireing and try to figure out where to stick all of those cathodes
  10. Pete_Venkman
    Pete_Venkman What's a Dremel?
    20 Jul 2005
    That sleeving does look real nice...very professional. It looks so good that it surprises me that it's your first go at it!
    I'm also diggin' the padding that you're laying around the case. If I might, where did you get that stuff? Looks neat.
  11. Fozzy
    25 Jan 2005
    Thank you about the sleeving. I got the padding stuff from Voyeurmods.com. They sell it the cheapest out of all of the dealers i have found. It can also be found at Frozencpu.com as well as xoxide.com. It's relatively cheap compared to painting. At only 12-14 bucks a pack (frozen cpu is 19) you can have your whole case covered. I bought 2 for this large case and i have more than enough. If i wanted to, i could cover every square inch.
  12. jakenbake
    jakenbake full duplex
    5 Jun 2005
    its soldering
  13. Fozzy
    25 Jan 2005
    haha thx
  14. Fozzy
    25 Jan 2005
    UPDATE 8/28
    SOrry in advance for the pictures i didnt realize the flash was off.
    What i've been waiting many moons for.
    The little box inside the big box
    I was a little dissapointed to see the swiftec label because i specifically ordered the D5 because of the changeable speeds. But, as it turns out, it has the speed switch anyways.
    Getting prepared for the start of another all-sleeving day. :wallbash:
    Here is the pump cable. I used a little extra Solder on this one.
    Sorry for the pic. It's the pump sleeved.
    be carefull with razors :thumb:
    This one even gave me a nice scratch.
    1 fan down, 1 to go
    all fans finished : )
    Started with the biggest set of cathodes. 1/2 of them done in one sleeve. I used 1/2inch chrome and was able to leave the molex's on
    Close-up
    Close-up
    Power inverters
    The next 2 i did together as well. I did have to take the molex's off these though because i used 1/4 inch sleeving. Or maybe it was 1/8th. Meh who cares.
    Close-up
    Power inverter.
    I also did 2 more cathodes by themselves but the pictures sucked so here is one of everything i sleeved that day. Or almost everything....
  15. Fozzy
    25 Jan 2005
    marking the pump placement on the underside of the case useing the mount and a sharpie
    almost straight
    Holes drilled. That black mark is the marker not a drill slip.
    Some grommets
    Another sheet of Pax that i can finally put in since the pump mounting holes have been drilled
    mmm black
    Mounting screws.
    figured out my flash.....and PUMP MOUNTED!!!!
    Full shot.
    I started plumbing and now you can see my first problem.
    I think i can remove the bay above it by drilling out some rivets so i think everything will be fine :thumb:
  16. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Hey hey, looking good :thumb:
  17. hitman012
    hitman012 Minimodder
    6 May 2005
    Nice sleeving - looking forward to seeing the WC loop in place :thumb:
  18. Fozzy
    25 Jan 2005
    thank you
  19. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    The sleeving indeed is looking good.
    Ehrm... with the wc: Can't you use like a 90° whatever-this-thingies-are-called? Damn... shouldn't have been smoking that much when I was 15... this really ********s up your brain for a long time. /me being 21 now :D
    :~subscribed.
  20. r00t69
    r00t69 What's a Dremel?
    2 Apr 2005
    Nice work on the sleeving Fozzy :thumb:
