FOZZBOX>>>>>>>>> 9/10 RADIATORS ARRIVED
Discussion in 'Project Logs' started by Fozzy, 16 Aug 2005.
  1. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    Haha. The problem with the pump has been fixed and no i couldnt have used a 90 degree barb because there wasnt enough clearance. I took out the drive bay above it and i'll upload some pics of it late. It's still pretty tight though so i think i'm going to find some coolsleaves for it
  2. Fozzy
    25 Jan 2005
    :clap:
    TY i'm m,ostly just glad it's over
  3. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Good to hear it all fits now. Waitin' for the pics.
  4. -Erik-
    -Erik- Guest
    drill some holes in that plate below the pump, add some molding .. and it should look really nice ... dunno if possible tho :D
  5. ZafaV
    ZafaV What's a Dremel?
    26 Aug 2005
    Can't wait to see this mod finished! :eeek:
    :dremel:
  6. Fozzy
    25 Jan 2005
    So am I. And thx
  7. Fozzy
    25 Jan 2005
    Just gotta get those radiators and the mounting hardware from polarflo.....
  8. Fozzy
    25 Jan 2005
    I think what you're saying is add a bottom window. I dont really want to because i want to keep everything as stock from the outside as possible. And if i just used molding and not plexi then my radiator fan would suck the dust straight up through the bottom of the case. But thanks for the input
  9. webbyman
    webbyman Hax.
    7 Oct 2004
    no pics :( your bandwidth has been exceeded :O
  10. Fozzy
    25 Jan 2005
    Only on the first couple updates. They'll be back at the beginning of next month due to photobuckets policy
  11. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    That and you'll kill your flow rate. Just make a few cuts, or rotate the pump body 90* on the mount, so that the tubing comes out the side.
    Pretty tubing you've got there. :hip:
  12. Fozzy
    25 Jan 2005
    Exactly. With the length of the tubeing, the three radiators, and the three blocks i simply cant afford to have a 90 degree barb in my system. I've fixed the problem but i need to upload the pics from the camera that is at my dad's house.....ugggh. The tubeing is some of the best stuff i've seen/worked with. EVER
  13. Arkuden
    Arkuden mow?
    9 Jul 2004
    hehe i really need to see how you got those rads in there... I just got my case in the mail yesterday and not kidding that i took 20 minutes just to stare at it. The features are incredible. I really have to give it to antec for a high quality case. Someone mentioned the flimsy front door but its actually quite strong. I was surprised. Now i have to figure a way to mount my vandal switch :p
  14. Fozzy
    25 Jan 2005
    The plastic on the bottom of the door that latches to the case is "flimsy" I removed the doors dureing the entire modding process and set them aside so they wont be damaged. The bottom rad is easy to mount if you remove the bottom harddrive rack and the mounting for it. The top rad i havnt dealt with yet and the rad on the back will be outside of the case with the tubes leading in. You can mount one more rad in the bottom front if you use some zip ties instead of bolts or drill out the holes in the grill for the fan. You can also mount another rad underneath the psu so the 120mm fan from that will pull the air. If 5 isnt enough then you can remove the second harddrive cage and mount another rad there. The only cuts you would have to make to mount these six rads is the back grill underneath the 120mm exaust for tubeing and the floor beneath the Psu to allow airflow to the bottom rad. You also have to drill out the rivets for the bottom psu cage and if you are like me drill out the rivets for the 3.5inch bay inbetween the 2 hd racks and make 2 straight cts on the bottom. If 6 rads isnt enough, there is lots of room on top for some dremel action. :D Hope that helps
  15. Fozzy
    25 Jan 2005
    UPDATE 8/30
    Fixed my Outlet problem. Here's a few pics to show what i did.
    Here's the first to rivets holding the 3.5inch cage that's in my way.
    First rivet gone
    Second rivet gone
    Another "hidden" rivet. It was covered by my aucoustic matting and the matting had to be removed and replaced to drill out the rivets.
    There was alot of grunt work (basicly takeing off pax mate to slide out the cage) that i didnt take pictures of because i was tired and just wanted it fixed. So i have a pic of the the finished product instead.
    As you can see the drive bay has been removed from the mid-section and now the hose has more bending room. I've ordered some coolsleves and i think that will keep the tubeing very sturdy with this tight curve. It's Blue so it'll match the tubeing as well. You can see in this next picture it is much better than before but still slightly kinking.
    This case was just made for watercooling
    I realized this update was sort of small compared to my others so i took this time to take some pics of my workspace and the chaos of modding.
    As you cvan see there is alot of stuff everywhere just from this mod. I'm anxious to be finished so i can throw everything away.
  16. perplekks45
    9 May 2004
    Then do it damnit! :D
    Very clean work with the routing fix. Looking nice. Keep this going.
  17. Fozzy
    25 Jan 2005
    Waiting for my 120mm rads and some polarflo mounting hardware. I'm going to finish it without the hardware if i have to but i do have to wait for the rads.
  18. -Erik-
    -Erik- Guest
    Yes, this update is sweet .. it was a bit what I had in mind. Looking really nice ;)
  19. Fozzy
    25 Jan 2005
    I thought what you had in mind was a window on the bottom. This is the case flipped upside down. And thank you
  20. Fozzy
    25 Jan 2005
    UPDATE 9/1
    I got a package in the mail today that spurred me into mounting all of my waterblocks so here's the begining of the water madness.
    Here's the pacakge.
    And here's who it's from
    Remember how voyeurmodz screwed up my order? Polarflo sent me the right hardware at no extra cost : )
    with the washers
    My old noisy chipset fan
    The new pretty waterblock
    All mounted. I may have to adjust it a little to make sure it's flat though
    My 6800 GT
    Pretty face plate huh?
    Some cooling for it
    Gt without the plate
    Ramsinks removed
    Just the Aluminum hs
    NEKED!!!
    Old crappy stock hs
    All clean!!!
    Perty blue zalman hs's
    With the polarflo
    Pics of it fitted
    A couple ramsinks i had lyeing around so i stuck them on some bare chips
    Talked to the guy about the radiators. They're on there way now....... stupid ebay
