Hardware Fractal Design Define R4 Review
Discussion in 'Article Discussion' started by Baz, 20 Jul 2012.
  1. Baz
    Baz I work for Corsair
    13 Jan 2005
  2. Ljs
    Ljs Modder
    4 Sep 2009
    I wish I could buy the removable drive bays for my R3...
  3. David
    7 Apr 2009
    Just swap it for an R4 - the missus will never notice. :p
    Guest-44432 likes this.
  4. Baz
    13 Jan 2005
    "Hey, did your case get slightly larger?"
    "Noooooo"
  5. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    Must. resist. changing. a. word.
    Loved the R3, surprised this didn't get premium considering the price. IB chips do need more cooling, or a razor blade, but what great features for £80
  6. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    let's see if we can cause the same commotion with the R2 review...
    WE DEMAND A FULL LOADED FAN TEST!!!
  7. Jehla
    Jehla Minimodder
    8 Jan 2010
    Maybe it's just the photos, but it kinda looks cheap. On a less subjective note, it would be nice to find out how well sound deadening materials work. Fancy doing an investigation? :D
    Also this, some manufactures seem to only put in the bear minimum number of fans. Which works for me since I either have a pile of fans, or I'll want to buy the fans I want.
  8. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Does it have more space behind the motherboard tray? It's the only fault I can find with my R3. I can cable manage in my R3 but it's hard because the side panel is a bit close to the motherboard tray.
  9. Parge
    16 Jul 2010
    Given the small changes from the R3, they may has well have just called the the R3 v2.
  10. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Well done review Harry. My only nag is the cooling comparison to Corsair's Carbide. Fractal's "Define" series has always been designed for "Silent" computing, with front insulated bezel doors and exterior, while the Carbide has an "Open Air" design. Two entirely different enthusiast markets.
    The R4 is a hybrid of the R3 and Arc Midi chassis. It utilizes the best features from both of these cases.
  11. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Indeed, this is the only real criticism I have with my R3. I only really appreciated how annoying it was to cable route properly after building up my wife's system in the Arc Mini.
    The removable drive bays are also a major plus as height aside the Arc Mini is a much design from a GPU fitting/ cooling aspect when compared to the R3.
  12. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    I say well done to Fractal for responding to the ever changing requirements of enthusiasts.
    They have:
    - added support for roof mounted all in one CPU coolers (or maybe slim radiators)
    - made the drive cage(s) removable
    - improved dust filters
    - improved support for tall CPU coolers
    - improved cable routing grommets that everyone moans about
    - improved 2.5" HD/SSD support
    All in under two years since the R3 was released. How many other case manufacturers are so responsive to their market?
    Of course I would love to know what teh cooling performance is like fully loaded but that will come, if not from bit-tech then from t'interwebs.
  13. megadriveguy
    megadriveguy Minimodder
    19 May 2010
    Any chance of Fractal updating the Define XL any time soon ?
  14. loftie
    loftie Modder
    14 Feb 2009
    I may have missed it, but did you just use the included fans plus cpu cooler? Did you use a side mounted fan at all? :)
  15. Fingers66
    30 Apr 2010
    Bit-Tech always just use the fans supplied, two in this case(!).
    The CPU cooler was the Gelid Tranquilo they use with their test kit.
  16. kingred
    kingred Surfacing sucks!
    27 Mar 2008
    I have an r2, the bitumen is starting to peel off on the roof, so I think the r4 will be the case I use when I get a new build.
  17. Necrow
    Necrow Minimodder
    24 Feb 2009
    I'd swear that I had this case a few years back.......the P182
  18. billysielu
    billysielu Minimodder
    12 Jun 2008
    It's at the bottom of the graph and you give it 84%.. right..
  19. pbryanw
    pbryanw Minimodder
    22 Jul 2009
    @Necrow - Hehe, I think this is what the P182/3 should have been with a sensible drive layout, better cable management and no (silly imo) PSU divider.
    Certainly gives me plenty to think about for my first upcoming quiet build. R4, Corsair 550D or (maybe) Antec P280? Looks-wise I think the Corsair wins, but the R4 is cheaper and has better cooling. The R4 it is then, and spend my savings on upgrading the other components.
  20. loftie
    loftie Modder
    14 Feb 2009
    I assumed as much, but wanted to check :p I'd be curious to see the heat difference with the side fan on, since the GPU temp seemed to let it down
    I don't really think it's a 'cooling' case, which is why cooling isnt amazing. It's more of a silent case, like the P180 from antec. It gets 84% because it's built well, has good features, and offers good value considering ( see 550D ). The P180 etc offers similar features, last I saw it it was over £100.
    Considering the delta Ts, I assume the GPU hit about 80-90C on low, and the CPU about 70-80C?
